Kenmore 24032\24036 Top Load Washer Logo
Posted on Aug 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kenmore washer model 110.82467800. It won't drain or spin. It does everything else but it won't drain or spin.
Anonymous
Level 3:
  • Master 949 Answers
  • Posted on Aug 22, 2010
Anonymous
Master
Level 3:
Answers
949
Questions
0
Helped
258743
Points
3036
This is most likely due to the lid switch being bad. The machine is designed not to go into drain or spin with the lid open, if the lid switch is bad, the machine may think the lid is open. Here is a link to a video that shows how to replace the lid switch.
No Spin
2answers
My kenmore top loading washer is not spinning and the spin lite just flashes also the lid lock lite is not on. lid does not lock any ideas?
If the lid does not lock the safety controls will not allow a spin. Look for a broken lid lock - either the lock assembly or the small latch finger that inserts into the lock.
With no model number there is no way to be more precise. Sears Kenmore is sourced from more than one supplier (manufacturer) and there are literally thousands of models over the years.
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Alexander
vince
