The dispenser will take about 6 oz of rinse aid if completely empty. It will only need filled every couple months depending on how often you do dishes.
If you are getting poor drying performance or spotting use a rinse aid that is called 'Turbo Dry'.
The arrow is how much rinse will dispense each load. Start out near the center, if you see spotting or turn it up slightly and try another load.
Good Morning friend, thank you for your post!
I see that you are having an issue with your rinse aid dispenser not adding rinse aid into your Frigidaire dishwasher. You may need to run hot water into your dispenser to help clear out any dirt or clogs within your dispenser. If that does not help I would recommend making sure the water temperature inside your dishwasher is at 120 degrees. If the water is not at the correct temperature it will not allow proper dispensing of the rinse aid. You may also want to check the filter at the bottom of your dishwasher to assure that it has been cleaned out and is not distributing dirt or debris inside of your dishwasher. I would also recommend checking the spray arms to make sure they are not dirty and spray water evenly. You can clean them out using a pipe cleaner. I hope this information is helpful to you. -Matt
I appreciate your post, jake!
Based off the information you have provided it sounds like a potential problem with your rinse aid dispenser or control panel within your Frigidaire dishwasher. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to have issues with the dispenser I would recommend contacting a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
