This is most commonly due to debris in the inlet of the pump. This will cause poor water flow to the upper arm and low pressure to the bottom rack. If you want to clean this out I have put together some instructions. Follow the link below and let me know if it helps.
Sump Clean out
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
