I'm having problems lawn mower. I have a Craftsman LT1000 42' mulch blades(2),Kohler engine 16 OHV. The engines run well, the problem I have is I can't get the blades to engage. I can pull up on the lever and it will only pulls so far..not enough for it to engage.
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
