GE (PSS26MSRSS) Side by Side Refrigerator Logo
Posted on May 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker My ice maker is not working, the water in the door works fine. i have replaced the filer and it still doesnt work. is there a reset button, do i need to check the lines? how could i do that?
  • duanecoller Apr 04, 2009
    My ice maker quit making ice, but my water in the door still works fine. Any ideas what I ought to check? Thanks.
  • Anonymous Apr 18, 2009
    my ice maker does not make ice, light is on and water dispenses but no ice being made. Filter has been replaced
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on May 20, 2008
Anonymous
Master
Level 3:
Answers
725
Questions
Helped
407053
Points
1785
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
1helpful
Samsung side by side ice maker not working
It might be low water pressure or the water filer or the valve has gone bad is faulty for your ice maker in your fridge.It
Ice maker reset
Either valve solenoid supplying water to ice maker is bad, or supply tube to ice maker is frozen(which is typically caused by leaky water valve), or ice maker is bad.
2014 Kenmore side by side refrig. Water comes out of the door fine. Will not make ice.Tried the reset button on the left by the bucket, took top of door apart to see if mechanism was froze up.
Hello Rhonda Cornett,
Okay... water at the wall is connected... good...
but now you have TWO solenoids at the ENTRY POINT...
It would have been nice to know if there is water in the tray...
or if it EVER WORKED... but whatever.
If you are NOT getting water in the ICE TRAY...
you need to check that wire is connected to ITS OWN SOLENOID... (ELSE: solenoid might be bad)...
You might be able to TEMPORARILY REVERSE the water valves
to see if the door service still works with the SUSPECT VALVE..
Still works ... Ice maker trouble...
Fails solenoid trouble (bad valve) replace!
Then restore EVERYTHING... (take pictures ahead of tampering).
That click (or thump) you hear whenever you fill your water glass.
Every ice-maker I've ever tampered with has an on/off switch..
Fill controls... and firmness settings of some sort...
Check'em all out before getting DRASTIC.
Not the correct ICE MAKER PARTS
(illustrative purposes only)
appliance part houses (sears = pricy (IMLTHO)).
Water Filters Lawn Garden Appliance Parts
My ice maker quit working.
Ice not being dumped out because the heating element designed to slightly melt ice so arms can push it out is non functional and needs replacement. Cheaper and better to replace entire unit at nominal cost.
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Water won't pump to the ice maker.
No button to push. It sounds like the solenoid valve which opens to fill the ice tray is not working. Not getting power, stuck, faulty.
2helpful
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
2answers
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
2answers
Top Refrigerators Experts
vince
Johnny 1000
