Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Ardell Watry Posted on Aug 20, 2010
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is disingaged seting on seat clutch disingaged. How can I now if it may be the switch or selinoid.
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
4054
Points
65
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Merc e320 1997 model,W210 engine wont start. Please help
If you hear a click while turning the key this would indicate low charge in battery any reading under 12 on a tester would have trouble starting other than that loose battery leads have you tried jumping if it starts with a jump this would indicate battery.
1helpful
2answers
'03 Navigator will not start.
Sound Like Transmission Position Sensor ... a sensor determines when you are in Park when stopped...if not, wont start...
Other solution could be Fuse Relay...do you hear buzzing sound coming from fuse box. If so, feel which one is failing and replace. $6 at Autozone....
Where is starter relay fo '06 zafira located?
Where is the starter solenoid on zifira b 1.9 cdti it won't start it's just making a clicking sound any one no why it's got a new battery on it help
1helpful
2answers
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
When I turn the key on to start my Troy-Bilt RZT 50 zero turn mower, there is nothing. No ignition light, nothing. I have a new battery and I put a new fuse unit but still nothing. Help!
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
Won't start; hear clicking sound coming from fuse box; no lights; key stuck in ignition. Please help.
please check your battery condition.
clicking sound you hear is from the magnetic switch ***'y of the starter.
no lights & stuck ignition key is caused by a low power or bad battery.
hope this may help.
How to see if my starter is good
Hi!!
First, check Starter FUSE and RELAY, if they are OK!! Follow this direccions to find out if your starter is busted.
When you turn the ignition key to the START position, if it cranks up (turns over), your STARTER IS OK, if it makes a CLICKING SOUND, the battery is weak, when you HEAR ONLY ONE CLICK, the starter selenoid IS GOOD, the starter may be the problem.
Good Luck!!
2helpful
1999 Dodge intrepid tries to turn over but won't/can't. Everything turns on electronically that's supposed to, brand new battery.
clicking sound heard? starts fast then slows down as you crank over engine?ok try this --at the starter there is an electrical connection -- B+red wire and a smaller wire make sure these connections are tight. if ok proceed to next step--if you hear a low clicking sound when you turn the key and when trying to jump start the car still hear a click sound have someone tap on starter while you try to start it --- if car starts the starter solenoid is bad,anything more please write me back, Lee Davidian
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
