Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
Posted on Nov 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a craftsman 46" 18hp lt 2000 the blade engaging cable broke and i replaced it but now it won't start. it try but it spins alittle like it wants to but stops. i took the spark plug out and it spins good like its should but when you put it back in it stops spining over again. any help would be a great help thank you
  • Anonymous Aug 20, 2010
    Howdy, it sounds like the safety cut off is still in the off position. Is it possible the blade engage control is misadjusted so that the mower still thinks the blades are engaged? I know this is not a solution, but you have my moral support:) I will keep thinking on your issue and perhaps one of us will get it. Good luck:)
Jim flowers
Level 3:
  • Craftsman Master 1,098 Answers
  • Posted on Nov 26, 2017
Jim flowers
Craftsman Master
Level 3:
Answers
1098
Questions
Helped
359413
Points
2966
Sounds like valves are out of adjustment. but since you just put a cable on it be sure it is on correctly and the belt releases the blades because if the belt is to tight it will not allow the engine to turn over past the compression stroke as you are saying.
5 Related Answers
donald boissonneault
  • 110 Answers
  • Posted on Mar 24, 2009
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 28, 2009
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Anonymous
  • 138 Answers
  • Posted on Aug 25, 2009
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Anonymous
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Anonymous
  • Posted on May 21, 2010
SOURCE: craftsman lt 1000, blades won't engage
Lever will go all the way up and lock. There is tension on cable but nothing happens
Blades won'e engage
Your belt may be on wrong or slipping.
2answers
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
2helpful
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 • Garden
2helpful
Craftsman lt 2000, blade not staying in place
i would need a complete sears model number to look this up for you, however, you will need to remove the intire blade spindle housing, then you can remove just the shaft from the housing. and just replace the shaft. Will save a lt of money.
if you can find the complete model number you can go on the internet to
mtd.com/parts or to ayp.com/parts
and you can pull up a parts diagram and find the exact part number and order it online, or take model number to sears and they will either have it in stock or can order it for you. Sears will however cost you a fair amount more then ordering online. I hope this helps you
Blades won't turn when I engage the lever to start them
sounds like the cable may be binding up. or there is an obstruction under it. take it off clean it good and spray some lubricant on all the moving parts. that usually gets the moving again.
Need a blade engagement cable diagram for a 2002 craftsman lt1000
1helpful
2answers
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
