Hi, you responded to someone's inquiry about their middle arm not turning. Mine is doing the same things and I don't think it is from build up in the arm. The arm turns freely and water is coming out easily, but it isn't turning. Can you elaborate on the water pressure possibility and how to confirm/fix that? Thanks!
My DW is a 24 in built in but the model number is GLD5500L15BB
SOURCE: GE Nautilus Dishwasher - NO water coming in at beginning
all fill cycles on a dishwasher is timed. so at the end of the fill cycle the dishwasher may run. the first thing I would check is to make sure the water inlet valve is good. for this you will need a volt/ohm meter. you will want to make sure that there is 120v going to the valve. if there is you then would want to remove the wire connector on the valve and ohm it out. if you get a reading anywhere from maybe 450-650 the valve should be good and you will want to check for a blockage. good luck
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
SOURCE: GE Triton arms don't spin
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
SOURCE: GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
SOURCE: middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Same here! We've taken the arm and tube-thingie off altogether to see if there is water coming out of the wall... and sure enough there is - powerfully, at that! Nothing is clogged anywhere, but no water pressure and the arm doesn't turn so the top rack is not clean... Actually, we're having a similar problem with the bottom arm as well... lots of pressure when the arm is removed, but it doesn't turn when the arm is attached... it spins freely.. not clogged... could it be the water pump??? weird... and frustrating...
