Question about Kenmore 44921 Front Load Washer
My kenmore front load washer has aquired this rank moldy smell. If don't take the washed load out immediately the nasty smell penetrates into the clothes and smells even after drying. Is there some sort of solution or remedy for getting rid of the smell in the washer? Some friends have suggested that we run a vinegar and bleach mixture through a couple of wash cycles, but we're not sure about doing that. Help?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
You can run a regular cycle with bleach as instructed in the manual. there may be mold on the rubber where the door closes. wash this with water and bleach. to avoid this problem in the future you can loosen the light bulb then you can leave the door open a little all the time with no light. press the off button when not in use.
Posted on Jul 26, 2017
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: Tub smells of stagnant water
This is a fairly common problem, where a bad odour comes from the washing machine, especially after a lot of low temp wash cycles. There is no component in the washer that can fail to cause a bad odour. In most cases,it will be from an external source, or the way the machine is used. Reasons can cause the problem : - liquid detergent - Do you use liquid detergent? There is no chlorine bleaching agents in liquid detergent and it has a tendency leave the machine smelling a bit after a while. The cure is to do a "Maintenance Wash" (a boil wash with no clothes or detergent in) at least once a month, or you can use dishwasher cleaner or bicarbonate of soda, both are very effective. -Backfilling from the house waste- Incorrectly installed of the stand-pipe outlet and/or U-bend, allowing dirty water from the drain to come back into the waher, via the outlet drain pipe. Check that no water coming slowly back to washer's tub when it's switched off. Good luck !!
Posted on Jun 05, 2006
Anonymous
  • 207 Answers
SOURCE: Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
Posted on May 08, 2008
Anonymous
SOURCE: smells of mildew and so do clothes
There is another product out there that seems to work real well.... it is called "AFFRESH" and it is for He front load washers... Its available at Lowes for about $6.50
Posted on May 29, 2008
Anonymous
  • 242 Answers
SOURCE: laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Posted on Dec 30, 2008
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Posted on Oct 01, 2009
Getting a smell out of a kenmore front loading washing machine
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude thiose nasty smells.
Aug 14, 2014 | Washing Machines
Tip
Excellent fix! I printed your instructions and was able to easily follow them...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
Where would i look for a lint trap on a whirlpool front load wash
if you remove the bottom cover you will see a round white dial..it will be full of water so beware! a gallon or more so be ready. unscrew it counterclockwise and remove filter. does it have nasty smelly lint it it? problem solved.this is all you can do so good luck! :)
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The hotpoint washing machine has aquired a nasty smell and after washing clothes they don't come out smelling nice and fresh like they used to.
Hi
the best thing to do is a service wash with galgon tablets on a boil wash.
this should sort it out.
regards
Mar 21, 2009 | Hotpoint WMA74 Front Load Washer
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Moldy smell in washer
run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
Jun 18, 2008 | Kenmore Elite 45986 Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 44921 Front Load Washer Logo
49 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
