Question about Schumacher & Fast Charge Starter Charger
HAVE NO IDEA HOW TO READ THE METER ON SE-82-6...RED AND GREEN TRIANGLES...DON'T KNOW WHICH DIRECTION THE NMEEDLE'S SUPPOSED TO BE GOING.
  • 843 Answers
The meter is telling you approximately how much current (amps) it is sending to the battery. When the meter moves all of the way to the right it is charging as hard as it can (that would be 6 Amps) which indicates that the battery needs a lot of charging. As the battery becomes saturated with charge, the meter will move toward the left. As the battery become charged, the unit automatically tapers off the current. The meter can indicate as little as little as zero Amps, meaning it is not charging the battery at all - which is the case when the battery is powered up, but isn't even connected to the battery. If it reads zero when it's connected to the battery, the battery is broken and can't be charged.
Since this charger is rated at 6 amps, it will indicate about 3 amps when the battery is about done. It won't normally go to zero because those 3 amps are getting wasted just heating up the battery.
Posted on Aug 16, 2010
    Problem Solver:
  • 4 Answers
Here's a pic of MY VERSION OF THE SE 82-6. SEVERAL OUT THERE.
http://www.northerntool.com/images/product/zoom_images/1677820.jpg
ok, as i was looking for manual online, it is more detailed than the one in box. it now explains this in picture detail. thank you schumacher.
here's the updated manual:
http://www.batterysales.com/downloads/SE-82-6.pdf
hope this helps.
Posted on Jan 23, 2012
Anonymous
SOURCE:
I have a Schumacher 6/2 amp dual charger, SE-82-6. I took off the clamps. Now don't know which wire is positive. One has a white line on it.
Get a volt meter and hook up the test probes to the cable ends and turn the meter on, the meter will say 12 or -12 if it says 12 then you have the red and black from the meter connected to the red and black on the charger in the right manner, if it says -12 then you have them reversed. Take the cable clamps and put them back on.
Mar 01, 2016 | Schumacher SE82-6 Manual Charger...
Where to connect green tacho wire on holden rodeo ra 2005 model
The green wire is always a ground you must ground it
Sep 22, 2017 | Cars & Trucks
Assuming red is positive, black is negative or neutral the green is usually an earth wire and should be mounted to the cars frame.
Jul 08, 2013 | Cars & Trucks
No spark
green wire to 1 coil black wire to other..and 1 red to each
Mar 13, 2013 | Suzuki Motorcycles
Powermate pm0545212.02 wont generate
The exciter coil can be checked with an ohm meter. It will read fairly low ohms (probably under 100). There are diodes also. You can check them with an ohm meter too. They should read in one direction only. The red lead on the meter is + and that will conduct through the diode when your on the anode. When you reverse the leads of the meter, it should read infinite or OL.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 27, 2009 | Coleman Powermate Powermate 5000W...
Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
Apr 26, 2009 | Jeep Grand Cherokee Cars & Trucks
I have a schumacher se-82-6,i dont use it much and have misplaced the instruction manual.how do i read the guage,when do i know battery is fully chargrd or battery wont charge? thanks erik
If you look at the meter, the charge meter of 100% is slightly above the 2 amp mark so it is confusing. because it says the charge represents the amont charged and the amp meter shows when there is no draw on the charger. so if the battery shows 2.5 amp on the amp meter, it's showing 100% charged. but yet they say it should go to zero on the amp meter, which would mean about 150% charged. i think everyone is scared of blowing up or damaging their batteries because the instructions manual is quite contradictory and confusing. well apparantly, they have several versions of this model to make it more confusing, but here's a pic of what i have.
hope this helps.
Feb 02, 2009 | Schumacher & Fast Charge Starter Charger
Schumacher & Fast Charge Starter Charger  Logo
6,234 people viewed this question
Top Schumacher Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
Lisa
Lisa
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
