SOURCE: Ice dispenser
I fixed it by replacing the solenoid that operates the flapper door and the flapper door. They came as a kit and both were broken.
I still have a problem which is a bad circuit board. I can't switch from ice to water. I am stuck on ice, so I have not bothered to fix.
SOURCE: ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
SOURCE: SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Testimonial: "new here--did not mean to rate you low..sorry!"
SOURCE: flapper in ice chute continuously freezing up
I am not sure but I think you have a bad door gasket in the freezer. This allows ambient air to come up through the chute.
Good Luck,
Gilshultz
