KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
Posted on Aug 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Anonymous
Level 3:
  • KitchenAid Master 43,501 Answers
  • Posted on Feb 25, 2011
Anonymous
KitchenAid Master
Level 3:
Answers
43501
Questions
0
Helped
10837156
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
1helpful
2answers
My Neff microwave H5470NOG/03 has stopped heating food, any ideas?
It has a internal Dio fuse..You have to take cover off to see it.. Warning...High Voltage...There pretty cheap...
1helpful
Why does my Hinari lifestyle MX780CEG make excessive noise from the magnetron area
Some magnetrons do emit a coarse buzzing sound, which is perfectly normal for them. If this is a new sound, though, it might be caused by something that has failed, or is failing, in the high voltage circuit. If the oven is not heating, the most likely culprit is the high voltage rectifier. A shorted magnetron or shorted capacitor will cause the transformer to hum much more loudly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Microwave has power will not start
When you say it just hums, do you mean that it sounds like it is running but isn't heating? Or do you mean that the sound is different from when it normally runs? Is it quieter or noisier than normal? Do you hear the fan running or is that sound missing?
IF it sounds normal (or about the same as when it worked), but it's nust not heating, then it is probably a bad magnetron tube.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
1helpful
My oven makes a humming noise when it is running - either in heat mode or defrost mode. The noise goes from nothing to loud, then loud, then it quits. The microwave is only 2 months old and it has been...
No! this not normal and should be checked out right away, the problem could be in the high voltage transformer being loaded down by the magnetron, or possibly the turn table motor. The warranty must still be in place and I encourage you to take at vantage of it.
1helpful
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
HI. I have a Whirlpool Microwave (MH6141XKB). It will not reheat the food and makes a louder "humming" sound than normal. Other than that, everything works fine. Please advise. Brent
Brent
The magnatron in your oven has gone out and will need replaced!( This is the device that heats up your food) If everything is working and your food is not getting hot 99.9 percent of the time its the Magnatron or its fuse! The loud humming is also a big clue the MAGNATRON has gone bad!
Please rate this response and help us keep this area free!
Thank You!
Load humming.(louder then normal.)
It does not heat.
I already replaced the HV diode. That did not fix the problem
It still has a loud hum and no heat. I'm guessing the magnetron.
The unit is six years old. I did not purchase it, the unit came with my house.
Model # JE1660MB002
1helpful
Smeg microwave working but not heating/defrosting etc. SA35MX model.
if it makes a loud humming sound it is something in the high voltage circuit. it could also be a bad microswitch in the door latch assembly
4helpful
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
