Please try to use a good lighting to check on the bottom to confirm the exact place of leak. It is possible that the drain hose is damaged or the drain pump is faulty and leaking. If so once you identify the spot remove and change hose , tighten hose clips or patch up the leak on the joints. I don think it will be an issue once you can look into the location and you must see it first. Hope you try. Good day
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
