If you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
vavle part number is W10175893 and is around 20 to 30 bucks
What he means is when you start a wash instead of filling and then agitating the machine starts agitating and filling from the start this just started happening to ours 'same model' and when it is doing its final spin water starts filling the tub as it is spining and remains in the tub when the cycle is over.,. 'please give advice '
open the top console,on the left side you'll see the water level switch or pressure switch same thing,pull off the plastic hose that's connected to it and blow into it,if you can't blow through it there's dried detergent stuck in the other end and has to be cleared out,if you can blow through it change out the timer
SOURCE: kenmore top load washer 29822800
Hi You'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
