Question about Bosch Axxis WFL 2060 Front Load Washer
Hi, have just purchased a bosch model was28440au, had been working no worries at all until this evening when i spotted a ten cent coin in the drum wedged in between the small inner seal, I had to let it run but when i checked it it was gone. i put on another load and the machine sat on spin cycle, ive checked the pump, filter and no coin heaps of water came out but couldn't feel a coin. How do I get it out or find it please, not sure how to access motor? Thanks
  • Bosch Master
  • 1,551 Answers
Hi .it might be likely that the coin is stuck in the pump .to access this you need to open the panel at the front and open it panel.see pic.please note that some water will come out when you open it.put a big towel in front.of it..
Posted on Jun 12, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
Anonymous
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: I have Bosch Nexxt Premium WFMC6400UC Front Load
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
Posted on Jun 18, 2010
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Have a WFL2480AU Bosch Front
Most likely to be the brushes in the motor that need to be replaced, check them for wear, and if less than 4 or 5 mm long, replace them.
Posted on Nov 08, 2010
Testimonial: "Great quick response."
Hi! Could you please tell me the value of a 2 cent coin? Thanks!
bring to a coin shop fixya doesnt do evaluations
Jul 25, 2018 | Finance
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Looking for service manual for Bosch was28469gb
Drum is split tub, not even a qualified engineer likes doing this as it takes a couple of hours. If drum needs a clean out, run a couple of 90 degree cycles with a capful of baby sterilising fluid directly in the tub. Or you can purchase a drum cleaner from Bosch direct via their website (Accessories shop)
Apr 02, 2013 | Bosch Washing Machines
We have a bosch front load stackable dryer that has coins stuck in the things that go around in the dryer, can we get them out?
You'll have to remove the top panel so you can loosen the baffles and get your coins out. Either that or take the back panel off and remove the drum altogether, which ever you find easier.
Jul 08, 2011 | Bosch Nexxt 500 Dryer
We have a 50 cent coin stuck in the end of the drain. 20 and 5 cent came out but 50 appears stuck, I can feel it but doesn't look like it will fit out. Do you think we will have to dissasemble the...
No brand No model. If you can see the 50c coin which is the problem, a handy hubby should be able to figure out how to fix the problem. Sometimes you have to 'cut out the problem'..
TIP Make sure the 50c coin hasn't got between the drums in a front load situation, because that situation can cause BIG problems.
Good luck
Nomess
Sep 09, 2010 | Washing Machines
Canon MP460 feeds the paper into the printer crooked. Seems to be feeding right side in, while left side of paper remains stable.
I just got mine sorted out. It took two things:
a. luck
b. a lot of googling
Now,
The problem was 15 cents of the Euro in the following configuration: 1x10cent coin and 1x 5 cent coin...
The first thing I did was try to clean the bottom plate and the roller. I read somewhere that using some thick paper does the trick. I destroyed an office paper file (not very thick, but definately thicker than normal papers) - about 5 - 6 tries on the bottom plate clean and the roller clean, and a 5 cent coin appeared out of nowhere :)
I though that was it but I was very very wrong. At about the same time, I got the mother of all annoying canon error 5100. Although the heads moved at starting of the printer, when it came to print it had the error. I looked as much as I could and I was convinced (several times) that there was nothing in the printer. The heads moved fine, but the error was there. Rebooted the printer about 50 times, took power off etc, but nothing.
After a good 5' search with the flashlight (mobile phone) I spotted a small shine right where the little spongy thing is under where the heads rest far right when you look inside from the front of the printer. And voila, a 10 cent coin standing glorious in there and causing me all this trouble. I couldnt access it at all, but I was able to use the force of gravity (by inverting and giving a little jiggle to the printer) to get it to drop and finally got it out.
The printer works fine now, paper loads like a charm and even colour photo printing is fine.
Now I need to find a way to put back that little plate I took out (totally unecessary in the end...) and I have to sort out the removal of tons of ink from my hands.
To sum up:
It can be fixed. It's a pain in the ****. You might get richer (15cents for me!!!). You will have a full functioning MP460 printer again.
I hope this helps someone else as well :)
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
MY SAT NAV WILL NOT WORK.THE ELECTRICITY SUPPLY IS OK CAN YOU GIVE ME A TELEPHONE NUMBER OF A RETAIL OUT LET THAT WILL DO REPAIRS TO A TOMTOMONEXL
Four in ten sat nav users have problems15 February 2007
More than four in ten people who have used a car satellite navigation system have got lost or made a journey which took longer than it should have done, according to a which.co.uk survey1.
38 per cent of survey respondents have used a sat nav system, but worryingly nearly half of them (43 per cent) have either got lost or made a journey which took longer than it should have done.
Around a quarter (26 per cent) of those who have got lost or had a longer journey said that as a consequence they use their sat nav system less, or not at all.---per Nicola Frame
For repairs and/or information visit this site
http://www.satnav-shop.com/
Feb 22, 2008 | Computers & Internet
Bosch Axxis WFL 2060 Front Load Washer Logo
205 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
