Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Not so much a solution, just a recommendation. I had the same problem with mine within a year of getting it. The dealer mechanic changed the whole joystick box and the problem was resolved.
