Just found the number and called, will have my replacement bowl in about 7 days, about 30 dollars. Not bad.....Just found the number and called, will have my replacement bowl in about 7 days, about 30 dollars. Not bad.....
You can't post conmments that contain an email address.
I fix a lot of plastic items with either super glue or 2 part epoxy resin.
Then for reinforcement at the edges. I take a 2cm (aprox) piece of thin wire. Like a staple. Then heat it with the soldering iron. sliding back and forth until the wire is embedded into the plastic. even slightly covered over.
This often makes a cracked piece of plastic quite strong.
It may not look great but it might hold you over till you find a replacement
Good Luck
Here are some ideas.... Repairing plastic parts
There is a small plastic piece on the lids 1-196 that slides into a slot in theback of the processer and is s safety interlock. unless your new lid will fit into that it will nto work. I know because i bought the wrong lid after the exact plastic piece broke on my original and I could not get the new one to work... right now my "work around" is to put both lids on.. the newer one does have the piece but its it the wrong place and I have to hold them while I use the processor.. sorry
I had a similar problem. Part of the lid had a small piece of plastic chipped away. It was the part of the lid that rotates and locks into the machine base. If the lid is missing a small piece of plastic on where it connects to the base, the machine will not switch on. You can compare the lid for the food processor to the mixing lid and see if the piece that juts into the base is broken at all. If it is order a new lid. There are several online places that still carry them; or try a local parts store.
I think you will have to look on your user manual at the back and see if you can find an adress there, I think you may have to write to them and ask them for a replacement lid?????
plastic piece broke on food bowl...not working...need replacement..........pls help
plastic clip has broken on the lid that activates the start.
Need replacement gasket for small cup
