Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
I have a Bosch Nexxt 100 Series WFMC1001UC/05 Front Load Washer that the brushes in the motor are wearing out. Were can I buy a set of brushes at? Any information would be helpful.
    New Friend:
  • 3 Answers
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Posted on Jun 25, 2012
    New Friend:
Part number is 154740 around 36 dollars from http://automaticappliance.com/ How to video from YouTube http://www.youtube.com/watch?v=N_r8d93xPYw&feature=youtube_gdata_player Different model washer but same motor. Look up videos for how to replace the belt if you have trouble. Symptoms of worn brushes include weak or no spinning.
Posted on Apr 30, 2012
    New Friend:
    Problem Solver:
  • 5 Answers
Ohio Carbon Industries is a manufacturer and distributor of carbon brushes for nearly all electric motors. Call our sales dept. at 419-496-4456 or email them at sales@ohiocarbon.com. We won't have a part number cross/listing for that number, but if you send one of the used brushes we could figure it out.
Posted on Mar 20, 2012
    Sergeant:
    Champion:
  • 353 Answers
Try Ebay it's pretty good
Posted on Aug 11, 2010
Anonymous
SOURCE:
Washer Drum Not Moving- belt is fine
Brand new belt and no other symptoms; my bet is the motor brushes. You will have to remove the motor to check this. there are 2 holders for the spring-loaded brush. I am guessing they are worn down and just stopped touching. It's a "silent failure" with no real symptoms except is doesn't move.
May 26, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer wont spin belt is on pump is free of debris
Possible that the main motor is jammed or does not get power from the program controller unit. It is important that you measure the voltage at the motor when the program is set to start after the inlet valve fills water. If there is no voltage then the program controller unit is faulty.
Click this link for support : washing machine tips
Jun 25, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Front load washer will not spin on spin cycle
brushes or moter check the brushes your self they should be about 4cm long
Jun 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
772 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
