Question about Whirlpool Washing Machines
My washer model number wtw6200sw0 keeps giving me an f1 error code. what do i do?
  • Whirlpool Master
  • 8,220 Answers
Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace
the machine/motor control assembly. See Accessing &
Removing the Electronic Assemblies, page 14.
WTW6200SW0
Tech Sheet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 10, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Can wash my clothes washer is giving a f1 announcement and stops.is a kenmore elite oasis model 110.27032602 quiet pak 2.thanks
    The F1 error code means that the control board has a detected a problem within the control itself and the control board would need to be replaced.
    The part number for that control board is W10189966 it could be picked up at your local appliance parts store or online at;
    searspartsdirect.com
    apwagner.com
    partselect.com
    apdepot.com
    repairclinic.com
    GENE
    Oct 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
    My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
    F1(F68)-Pressure Signal Out-of-Range
    I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
    Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I am alway getting the f1 code
    Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
    • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall!
    Nov 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
    There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
    Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
    There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
    Dec 07, 2009 | Cars & Trucks
    Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
    Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool washer Model WTW6600SW2. Error F1
    My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
    Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio model wtw6200sw0 serial number ct3471269 type 581, it has an "F" on the screen, it stalls out when it is washing as if the motor gets stuck and then it flashes "F"
    Sounds like a motor problem , F is for fault often a number with it , this is a fault code , refer to your hand book for explanation of these.
    Nov 09, 2009 | Whirlpool WTW6400SW Cabrio Washer
    Washing Machines Logo
    168 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
