Motorcycles Logo
Ryan Handly Posted on Aug 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a wire diagram for a 1981 harley davidson superglide for the starter wireing
Anonymous
Level 3:
Brigadier General:
  • Master 4,565 Answers
  • Posted on Aug 08, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4565
Questions
0
Helped
2155773
Points
14358
The wiring is simple for a starter. You have a starter solenoid on the bike and a starter relay. When you press the button to start your bike, the button has a wire that runs to the relay. This triggers the coil in the relay and pulls the contacts in. You have three wires that run to the relay for the starter. One hot wire, a trigger wire from the starter button and a wire from the relay to the solenoid. When you press the button, the relay pulls in and makes the wire going to the solenoid "Hot".
The solenoid has three wires going to it. The large battery cable goes to the "long post" of the solenoid, There's another battery cable going to the starter from the bottom of the solenoid, The wire from the starter relay goes to the small terminal of the solenoid. The small wire from the starter relay is the trigger wire for the starter solenoid. When this wire goes hot, it magnetizes the solenoid and pulls the plunger inward. The plunger bridges two large contacts in the solenoid to put high current voltage to the starter.
If you need a schematic, contact me directly at [email protected]. I cannot send a file via this medium but I can direct e-mail. Remind me of what you need when you contact me.
Good Luck
Steve
Re-wired the 1981 FXWG Harley Davidson Shovel head. There is still no power to anything. Need a wiring diagram.
contact me directly at [email protected] I think I have a wiring diagram that I'll send you. Don't forget to remind me of what you need and the year and model bike. I get a lot of requests and I can't remember who needs what.
Steve
2007 Dyna Super Glide FXD, Do I pull the starter out without going into the Primary ? seems you do..
You need to pull primary. Then remove starter gear bolt. Disconnect battery. Then remove 2 starter allen bolts. Disconnect battery off starter and start wire. MOPAR KENNY
How does the wiring go to hook the battery back up on a 2010 dyna superglide. harley davidson
The cable coming from the starter goes to the positive side of the battery. The cable coming from the frame connects to the negative side of the battery. There may be an auxillary power wire. If it's red in color, connect it to the positive side of the battery. If there is a charger pigtail, connect the red lead to the positive lead.
Good Luck
Steve
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
