Toro Lawn Mower With Toro Power Tools Logo
Posted on Aug 04, 2010
I have a toro lx500 riding mower. the blades won't engage.
Anonymous
Level 1:
New Friend:
  • Contributor 144 Answers
  • Posted on Aug 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
144
Questions
Helped
47306
Points
13
Check the belt on top of the mower deck. Make sure the belt didn't slip off or break.
My toro lx 420 wants to stall when engaging the blade sometimes..also when I push on the reverse, it acts like to wants to stall as well...any easy troubleshooting ideas? runs fine when not engaged
Try rolling when you engage instead of in the still position may be too much on the motor, either that the belt is loose or needs to be replace. Or u need a carb adjustment at the idle.
What type of oil do I use in my Toro LX500?
In the northern US, I would use a 5W - 30 year round, or 30 in the summertime. Do not use "non-detergent".
In the southern US, I would use a 10W - 30 or 30 in the summertime. No non-detergent.
Nov 06, 2015 • Toro Garden
Blades won't engage on my toro ss 5000 zero turn mower
for any ride on machine that the blades don't engage id start at looking at occupancy seat switch , these are most times the culprits then if that's ok I move on to the actual engage switch and then on to clutch as last element
don't forget that past 2013 mfg machines operator must be in seat and weight over 80 lbs , the clutch pedal must be depressed and transmission not in reverse to engage the blades on a consumer grade lawn tractor (thank the CSB for that )
Aug 27, 2015 • Toro Garden
1helpful
Toro lx500
You are listed in the wrong section of Fixya. This section is for Cars and Trucks. List in a section more closely matching your product to reach an appropriate Expert.
Aug 28, 2013 • Garden
The blades will not engage when the knob is pulled....toro 50
.... burning rubber smell? Sound like you have done a cutter belt.
May 27, 2012 • Toro Garden
Toro riding lawn mower pto switch not engaging to turn blades
see if you have power and ground to the connector that goes to the clutch it could be a bad safety switch
May 21, 2012 • Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Ride on lawnmower isnt starting.
You may have a bad starter - the solinoid is "clicking" but not engaging. Remove the starter and clean it up and connect it to 12 volts to check if can turn. If not then buy a new starter and replace it out.
Aug 03, 2009 • Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
