Hydraulic Clutch System
BLEEDING
The clutch system can be bled using a pressure bleeder. Follow the instructions that come with the pressure bleeder for the proper pressure bleeding procedure. The maximum line pressure while pressure bleeding must not exceed 36 psi (248 kPa).
NOTE: To bleed a clutch manually requires the assistance of a second person, a section of hose that is compatible with brake fluid (preferably clear) and fits the slave cylinder bleed screw snugly and a container to catch the fluid that is bled through the system. As brake hydraulic fluid easily absorbs moisture, always use fresh fluid when bleeding a hydraulic system.
how can i located the slave cylinder
