Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
Posted on Aug 02, 2010
Bosch logixx code f-23 .wat does it mean? - Bosch Logixx WFT 2806 Front Load Washer/Dryer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9962
Points
8
It means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
1 Related Answer
Anonymous
  • 414 Answers
  • Posted on Jul 07, 2010
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Bosch logix8 comming up with the code nro
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
1helpful
2answers
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
6helpful
My Logixx 8 washing machine is stuck at error code F:23. What is that waiting for ?
Unfortunately it is waiting for an engineer to investigate 'flooded base s/w activated' which is what the Bosch Logixx F23 stands for ;-0(
Sorry.
John C
16helpful
F:23 code logixx edition75
Hope this helps.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
