The other day, the dehumidifier stopped working and on the front panel, it lights up and show the following (CH) (01), I don't have a clue what this means, and after about a day, it restarted and then a few hours later, we got the same message. I don't know if it's a fuse or something is clogged or what. If somebody could help us, it would be greatly appreciated.
After checking the micro switch for continuity, someone else suggested replacing the humidity sensor on the front of the evaporator coil (6877A30013L). These parts are only available in individual repair parts that must be soldered onto the circuit board.
Try cleaning out the sensor with alcohol and blowing it out til it's dry.
This worked on my unit
I believe it is a water tank code. Re-seat the tank, unplug wait 15 seconds and replug the power cord and see if this resolves the error.
Background relating to other possibilities.
When the water bucket reaches its capacity, the bucket switch opens to shut off the dehumidifier. If the bucket switch fails while it is open, it will prevent the dehumidifier from running. To determine if the bucket switch is defective, use a multimeter to test it for continuity. If the bucket switch does not have continuity, replace it.
SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: My LG LHD45EL Dehumidifier is showing a ch 01
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
SOURCE: dehumidifier reads CH 01 Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
l'';';l
SOURCE: Display reads CH 01 and dehumidifier does not come
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Here
show that the bucket is full when it is not.
Dehumidifier
heatman101
