What do the colors for the capacitor wiring indicate there are 4, I have a S3QA 030K AC unit Intertherm What do the colors for the capacitor wiring indicate there are 4, I have a S3QA 030K AC unit Intertherm
all my wires in mmy furnase from the transformer to the contacters have been cut and i am trying to re wire them my selfall my wires in mmy furnase from the transformer to the contacters have been cut and i am trying to re wire them my self
You can't post conmments that contain an email address.
Your unit is April 2003. So it is 8 years old. P3D is model ref 0304 is year/month of manufactor. You also have a 2.5 ton system. Hop this helps. Info verified through local Intertherm distributor.
Intertherm is Manufactured by nordyne Inc.
Id recommendwww.nordyne.com
At least they could get you to the write people that may have the info you need.
I am sure there is one to download. If google is no help, just ask some deep web specialists, e.g. http://manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Wiring diagram is normally included and fixed to the inside cover of the electrical end cover of the control compartment. Instructions for wire size required and fused disconnect should be on the unit name plate.
There is no reset button on most of these units. If nothing is running at all when a call from cooling from the thermostat is made your problem could be a tripped or breaker in the off position. When you turn the thermostat to cool have someone listen for a click at the unit. If no click is heard it may be in the low voltage circuit that your problem is. If a click is heard which is the main contactor pulling in to run then your problem may be in the high voltage power supply. If you have a fused disconnect check the fuses. They should be of the time delay type (slow blow) and sized according to the ampacity on the unit name plate. Also check the main breaker in the house power panel.
I need a wiring diagram for a intertherm model #e2eb-015h,017h
