Runs then the engine cuts off when you try to spray
The problem you are describing lies in the engine. In most cases this can be cleared up by doing a tune up. In the meantime you can try choking the engine slightly and see if that keeps it running under pressure. This will usually solve the problem with the smaller GC and GX series Honda engines until you can do the general maintenance.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Engine stall or RPM fluctuates
at idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
