Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
My Lexmark 5400 series has just recently stopped working. It says "cannot retrieve application list". The printer and fax work just fine. I just installed the new Norton Internet security. I think that this might have affected it. Any solutions?
  • 45 more comments
  • Anonymous Apr 25, 2008
    printer won,t scan to email
  • Anonymous Jun 02, 2008
    Lexmark X5495 unable to scan because i received a message cannot retrieve the application list. But I am able to scan to e-mail.
  • Anonymous Jun 18, 2008
    list applications for printer
  • mcgutch Jun 25, 2008
    I have it hooked up and it says Cannot retrieve application list
  • tattletale20 Jun 26, 2008
    my printer can scan but its saying application cant retrieve and i got to scan its very important that i get this fixed
  • Anonymous Jul 10, 2008
  • corteriousto Jul 16, 2008
    cannot retrieve application list" Won't Scan - HELP please! problem, and notify you when a new solution is offered.
  • Anonymous Jul 28, 2008
    Exactly the same problem.Have contacted Lexmark,who emailed to me a
    possible solution,but to a novice like myself it looks quite complicated,and I have had neither the courage nor time to try it out,,as yet.
  • gundam385 Aug 04, 2008
    wont scan application list not found
  • kezzydee Aug 12, 2008
    i have the same problem with my lexmark 3500 4500 series. it asks me to select a computer so i select the one its connected to of course, it then says 'downloading application list' and after a few moments comes up with 'cannot retrieve application list'. its very annoying as no-one seems to have any explanation for this. i checked that the scanner drivers have been added and the rest of the printer works fine. HELP PLEASE ITS DRIVING ME MAD!!!
  • Anonymous Aug 29, 2008
    Exactly the same problem. Certainly wouldn't by a Lexmark again...
  • 182004 Aug 30, 2008
    I have a multifunctionLexmarc printer serie 5070. The printer and fax work just fine but not as a scaner. The mesage is: "Cannot retrive application list". What can I do?
  • Anonymous Sep 12, 2008
  • GoodNuke Oct 18, 2008
    I have the same problem with X9575. Any solutions?
  • Anonymous Oct 23, 2008
    when i put scan mode it says downloading aplication, but after that it says cannot retrieve aplication list
  • Anonymous Nov 06, 2008
    Having the same issue after reformatting my Vista computer.
    help!
  • bethr_89 Nov 09, 2008
    I have the lexmark X4580 and when i try to scan it says cannot retrieve the application list???
    what do i do?
  • cstockdale Nov 19, 2008
    Exactly the same problem. I am having to fax to myself currently.
  • Anonymous Dec 04, 2008
  • taye6 Dec 13, 2008
    Have the x5450, and same error message about application list. Called Lexmark support and let him take control of my system, and he couldn't figure it out either. Now what do I do???
  • Anonymous Dec 14, 2008
    ME 2 NEED HELP
  • Anonymous Dec 29, 2008
    mine is #5495 Scanner - brand new - same thing - i've worked on it for over 30 hrs ! - Lexmark no help at all ! - ready to blow it up - found out that the Scanner part is NOT plug & play & is digitized _ problem with windows XP interface
  • Anonymous Dec 31, 2008
    i just spent money on this stupid **** a few days ago. I'm going to return it to the store and get the printer/scanner/copier i originally wanted.
  • lynnherron Jan 22, 2009
    I have my computer hooked up to my computer and it is saying that it can not retrieve application llist and then it will start to try and download again just keeps doing this. How do i fix this?
  • Anonymous Jan 24, 2009
    Lexmark Scanner "cannot retrieve application list" Won't Scan - HELP please!
  • Anonymous Jan 29, 2009
    Same thing x4500. Piece of ****.
  • Anonymous Feb 09, 2009
    x3550 same **** - and the file is so big to download
  • ssziv Feb 10, 2009
    when i tried to scan i received the "cannot retrieve application list" message so then i downloaded the driver for vista and in the middle of the installation via the USB cable it gets stuck. now i don't have any driver!and no scanner
  • Anonymous Feb 12, 2009
    my wireless went out and now this!
  • Anonymous Feb 14, 2009
    The scanner has been used 4 times and now it says "Unable to retrieve application list."  I have e-mailed Lexmark. I have tried live chat.  I have re-installed the software and drivers.  I unplugged it. I have a Mac.  Can anyone offer a different suggestion?
  • razr3g Feb 23, 2009
    my x3580 displays ''cannot retreive application list'' when i try and scan. can someone help me with this
  • Anonymous Mar 04, 2009
    This fix worked for me on my Vista laptop and Lexmark X4530:
    Unable to Retrieve Scan Application List on the Lexmark 3500-4500 Series
    What you will see
    It is not possible to retrieve the scan application list during the Downloading Application List step. To determine if the resolution below should be used, the following should also be applicable:
    • It is possible to print either with a network or USB connection.
    • It is possible to scan using Windows Photo Gallery (in Windows XP using the Scanner and Camera wizard). NOTE: This can only be tried with a USB connection.
    • If scanning from the Imaging Studio software, you should be able to
      scan with a USB connection but the Scan to PC option from the operator
      panel should fail when connected via USB.
    Resolution
    There is a patch that you can download and run to resolve this issue.
    Step 1:
    Download the following patch: ftp://ftp.lexmark.com/driver/inkjet_drivers/3500-4500/3500-4500.exe
    1. To start the process, double-click on the downloaded file and follow the on-screen instructions to continue.
    2. Reboot the PC.
    3. Unplug the power adapter from the back of the printer.
    4. Plug it back in after 30 seconds.
    5. Try to scan again.
      If the problem still exists, follow Step 2 below.
    Step 2:
    Download the following patch: ftp://ftp.lexmark.com/driver/inkjet_drivers/3500-4500/3500-4500wifiethernetpatch.exe
    1. Double-click on the downloaded file and follow the on-screen instructions to continue.
    2. Reboot the PC.
    Still need help?
    Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for support, you will need to know your machine/model type and serial number.
    Please call from near the
    printer and computer in case the technician asks you to perform a task
    involving one of these devices.
    i cant connect to my coputior
  • Anonymous Mar 17, 2009
    Cannot retriever application list for scanner
  • dingogt Mar 18, 2009
    it says it can't retrive the application
  • Anonymous Mar 25, 2009
    fuckkkkkkkkkkkk
  • Anonymous Apr 01, 2009
    Mt sanner won't scan my papers
  • fixyapro Apr 02, 2009
    i cant get it to scan at all not from the all in one control panel and not from the printer board,this sucks.
  • Anonymous Apr 08, 2009
    it says downloading application list then says canot retrieve application list
  • Anonymous Apr 18, 2009
    I recommed you never buy Lexmark printers. I have a X4580 with the same problem as everybody else. Have had the printer changed three times. They really are rubbish. I am going to throw mine in the bin
  • jeffthomas72 Apr 30, 2009
    I have the Lexmark X4530 and it is saying the same thing: "Cannot retrieve Application List". I went to Lexmark's website and followed their instructions to fix this problem. I was able to get three scans to work and then it stopped again. I have had this model for about a year and each time I need to scan something I have to download the driver again. And each time it only works for a few minutes. They suggest using the 'Scan' button on their 'Lexmark imaging suite' from your computer. There is no Scan button on the screen or anywhere on there. It clearly tells you to use the controls on the printer, which of course doesn't work. I do not recommend buying a Lexmark printer.
  • Anonymous May 11, 2009
    cannot retrieve application list for scanner
  • rosafisher74 Nov 01, 2009
    I need a 5070 printer installation progam downloaded to my laptop
  • leolawrenceo
    leolawrenceo Jul 10, 2012
    Lexmark 6300 - After appx. 30 scans I got the same 'application list' problem, copier works fine, but cannot scan..after seeing all the reports of people having the exact same issue on so many different models and the fact that Lexmark neither lists my product on their website or offers any kind of real help for these issues, this will be the last Lexmark product I will use. I will make sure everyone I know is aware of this and to not waste their money on Lexmark products.
  • Jackie Aug 12, 2013
    Disable your Firewall and it will allow it to scan. I have the exact same scanner and had the same issue when I installed the new Avira. So whenever you go to sue it, disable to firewall and it will be able to retrieve the application list so that you can use it.
    I ahve the exact same scanner and had the same problem when I installed the new Avira. Disable your firewall while using the Lexmark scanner and it will be able to retrieve the application list. Enable it again when your finsihed of coarse. But this will at elats make your scanner useable again.
    New Friend:
Microsoft Paint ----> 'File' -----> 'From scanner or camera' (while the Lexmark is in scan mode). Just tried it and it really works.
Posted on Jul 07, 2010
  • 10 more comments
  • tekkiangel Mar 30, 2011
    OH MY GOODNESS! That is a pure stroke of genius. Well done, that does absolutely work. Whatever is wrong with the Lexmark communication between pc and printer, ie it just doesnt work no matter how many times you download the driver, or stand on one leg and face north, it dont work. This work around it classic and it works. Excellent, brillant, thank you. Good lateral thinking!
  • tkreisler Mar 30, 2011
    YOU DA MAN!!!! How stupid. Not you , but how stupid that going thru paint works and direct from the lexmark program. Maybe you should work for Lexmark!! :)
  • leroy60 Apr 11, 2011
    Brilliant! After many hours of frustration ... having loaded new drivers on numerous occasions, this works FIRST TIME EVERY TIME!!!
  • norma3230 May 28, 2011
    Thank you, that solved the problem...
  • sempervirens Jul 21, 2011
    You evil genius! Fantastic work-around. Thanks for sharing!
  • claudiasb Aug 04, 2011
    Holy mother of good THANK YOU SO MUCH!!! It only works through USB connection but I DOn'T CARE IT WORKS!!!
  • Mark Kull Aug 09, 2011
    This suggestion was so "simple" I almost skipped it. I'm really glad that I didn't. Thanks, Lucy.
  • Dudecanfixittoo Nov 23, 2011
    Actually, I've had a lot of issues scanning with my Lexmark at first too!
    I work a lot with Photoshop after I scan in pictures/cards etc with my Lexmark X4690 (Windows Vista SP2 64 Bit OS)... this theory also works in Photoshop just as it does in MS-Paint!!
    All you have to do is:
    Click----->'File' ---> 'IMPORT' ---> 'Lexmark 3600-4600 Series' (or whatever Lexmark Model you may have CLICK THAT!)...
    After that another window should pop-up... asking you "What do you want to scan?...using Lexmark 3600-4600 Series... from here you adjust the settings as you would in the Lexmark Productivity Studio suite. Only thing is, you won't need that anymore!
    HIT 'SCAN'... and when its done you should have not only scanned your document/picture/card etc.. you will have also imported it into Photoshop for editing!!
  • leslies814
    leslies814 Feb 14, 2013
    Wow amazing!! Thanks so much for the info I tried it and it does work!!!
  • Toni
    Toni Apr 19, 2014
    Thanks! I was having trouble with my Lexmark x5450 and when I scanned through paint it bypassed all of the problems I had trying to dowload through the lexmark software.
  • Talisa Stewart Jan 06, 2015
    I have a lexmark x6570 all in one and my printer works just fine but when trying to make a copy or scan items it prints/displays a all black document. I contacted lexmark support and they tried to trouble shoot it thru the serial number but no help. I have been uninstalling and reinstalling for hours now trying to get them to work. I even just tried thru the instructions above and still black documents. Can someone PLEASE help me?
    Hi. I have a lexmark x6570 all in one, my printer is working perfectly fine but when i try to make a copy or scan an item i get all black documents. I have called lexmark support and they tried to trouble shoot it thru my serial number but no help. I have been installing and uninstalling the soft ware for the past hours still not working. Also i just followed the above directions an yup still a black document. Can someone PLEASE help me with this problem I am having?
  • 11 Answers
I have a Lexmark X5495 – This worked GREAT for me so Good luck.
1) Power on the Lexmark.
2) Unplug the device from the back of the Printer
3) Wait exactly 30 seconds and then plug it back in.
4) (Assuming you have windows xp) Go to start/All programs/ Lexmark XXX
5) Open the Lexmark Productivity Studio (depending on your model of Lexmark)
6) Click on Scan – The device should be working now.
7) You can also use the scan button now.
Posted on Apr 25, 2009
Same problem,but found that in my case, opening Lexmarks All In One Centre,and clicking on the scan icon there,scanning occurred normally.
Posted on Sep 22, 2008
  • lisa67890 Feb 22, 2011
    i cant find the all in one center. i used to have thaton my old laptop. but i dont on my new one
  • TwansbaeNJ Mar 11, 2011
    I don't have a Lexmarks All In One Centre...I went to the start menu--->Selected Lexmark Productivity Studio. Once the program opened I just clicked Scan and everything worked just fine. Thanks!
I found that updating the drivers, off Lexmark's website, took care of the problem --
Good luck --
mj
Posted on Jul 21, 2008
    New Friend:
This is the worst product I have ever purchased. DO NOT BUY LEXMARK.
Posted on Jan 23, 2011
    New Friend:
I had this problem. As long as you can print to the scanner, all you need to do is ensure that the Lexmark Imaging Studio is running on the machine before trying to scan.
There will be a little rainbow coloured flower icon in the System Tray if it is running. If it is not then Start > All Programs > Lexmark (Printer number) > Lexmark Imaging Studio to start it.
Posted on Mar 01, 2010
Must run Imaging Studio, or another connection software on the background. Otherwise, Lexmark "cannot retrieve application list".
Cheers!
Posted on Jul 09, 2009
Hi guys,
I encountered this problem with my Mac and found a workaround by killing and restarting two of the driver programs. This may not work for everyone, and is probably no use to people seeing this problem on a Windows/Linux box (sorry).
Script:
killall LexmarkNetworkServices
killall "3500-4500 Series Button Monitor"
open "Library/Application Support/Lexmark/LexmarkNetworkServices.app/"
open "/Library/Application Support/Lexmark/3500-4500 Series Scanner.bundle/Contents/SharedSupport/3500-4500 Series Button Monitor.app/"
See the blog post at http://vaguevagaries.blogspot.com/2009/03/lexmark-x4550-wireless-woes-with-os-x.html for a little more detail.
Posted on Mar 06, 2009
    New Friend:
  • 3 Answers
I went into the lexmark series center, "change network scan settings..." and changed the name of my computer to one word with no spaces and it worked
Posted on Feb 22, 2011
    New Friend:
Scanner won't function because cannot retrieve application list
Posted on Jul 18, 2010
  • Randy ESEP Jun 20, 2011
    My x6650 has not been able to scan since the install of Windows 7. sometimes if I do a complete reinstall of the printer I can scan one or two pages, then it says
    again. Key symptom - lists computers that do not exist, but not the one I am trying to scan to.
    Definitely unplug the USB port before scanning to the wireless connection.
    I really did not mean to buy a 3 in 1 printer, I need a 4 in 1.
Same problem resolved on my Lexmark X4530 on Windows Vista with the following:
Unable to Retrieve Scan Application List on the Lexmark 3500-4500 Series ID: ENUS28866 What you will see It is not possible to retrieve the scan application list during the Downloading Application List step. To determine if the resolution below should be used, the following should also be applicable:
  • If scanning from the Imaging Studio software, you should be able toscan with a USB connection but the Scan to PC option from the operatorpanel should fail when connected via USB.
Resolution
Step 1:
  2. Reboot the PC.
Step 2:
  2. Reboot the PC.
Still need help?
Please call from near theprinter and computer in case the technician asks you to perform a taskinvolving one of these devices.
Posted on Mar 04, 2009
    New Friend:
Hi for MAC users try : -System Preferences -Sharing -Firewall -STOP: Firewall on - Printer Sharing
Posted on Sep 14, 2011
    New Friend:
I have had this problem repeatedly with an S305 on my OSX Mac. ... It prints just fine, but can't download the application list to scan.
Strangely enough, I've found that if I *unplug* the S305 (don't just power it down), wait about 10 seconds, and plug it back in, the machine usually returns to full functionality. Doesn't work the first time, try it again.
This is not to say that Lexmark's products which suffer this problem are well-designed or aren't pains in the posterior.
Posted on Jun 21, 2010
    New Friend:
I got my printer scanner to work::
Uninstall program::
Disconnected the USB ::
Restart computer::
Lexmark 5400 Disc in ::
My computer ::
Open disc Lexmark 5400::
Install from >Applications ::
Click and open applications::
Click setup to start setup
In the setup I did not install fax as I have not got a telephone line
At the end of setup it did not install drivers
The USB connection will
I then connected the USB
Computer: Found new hardware wizard and this found the drivers
On my machine wizard it did it twice
whaler it works
Posted on Apr 10, 2010
    New Friend:
What you need to do is check to see if your scanner is using the same wireless network as your computer. Push the "scan button," now select your network, finally choose computer if you have more than one using the machine. If your not on the same wireless network, open your lexmark productivity studio to configure scanner. You may be asked to connect your computer to your scanner using a usb connection so have it on hand. Run the diagnostics and you should be set.
Posted on Sep 02, 2010
  • bgc_ed_dir Mar 08, 2011
    My suggestion would be to check your firewall. Some Security programs change your settings to make sure your totally protected. Just go to Control Panel and select the Firewall icon. Click "Exceptions" tab and locate your printer and it's additional programs that need to get online. If you cannot find your printer, select "Browse" to locate. Hope this helps....
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Step 1:
Click here to download the 3500-4500/3500-4500.exe patch.
Reboot the PC.
Try to scan again.
Step 2:
Click here
to download the 3500-4500/3500-4500wifiethernetpatch.exe patch.
Reboot the PC.
Try to scan again.
Lexmark Printer Technical Support Phone Number 1-800-213-8289 for repair and configure Lexmark printer by our certified printer technician. Being an American corporation, Lexmark printer makes an extensive series of printers for a wide group of customers across work groups. Lexmark mainly makes printer series for industrial groups who need extra copies of prints at large scale in different formats. Customers can feature black & white to colored print patterns in various sizes with at least 24-hour Lexmark Printer Support Number.
Posted on Jul 25, 2017
    New Friend:
  • 3 Answers
Lexmark Optra S 1620 latest version drivers Download with free Driver Download And installation guide for your Lexmark Optra S 1620 printer to expect quality print results.
To have Lexmark Optra S 1620 driver along with utility setup in your system, follow our easy installation process.
It takes just few minutes to install this driver.
Click on "download" button, save it to your desktop.
Double click on the file; you will get setup box, click "Install",
Please make sure that you agreed terms & conditions then click on "Next" button until you get "Finish".
Click on finish button to end the installation process.
Now you have successfully installed Lexmark Optra S 1620 driver. Lexmark Optra 1620 Drivers Download For Windows 7 Xp and Vista
Posted on Nov 29, 2014
    New Friend:
It's not a "fix" per se, but try scanning from the printivity center. I was able to do this when scanning to network was unable to retrieve the application list.
Posted on Apr 28, 2013
    New Friend:
The "Paint" option below DID work, but, better still, I went to the Lexmark site and downloaded the latest full install for my OS, Win 7, 64 bit, then went through what seemed to be the exact same installation procedure as with the CD that came with the printer/scanner/copier, the S301 series, including not hooking up the USB cable until so instructed, and, Voila'! It now seems to work as intended. I guess that's what you get when you buy a $40 Lexmark item.
Posted on Sep 06, 2012
Peanut you were spot on.its the firewall that is blocking the scanner .
Sean
Posted on Oct 19, 2009
Doesn't work... try downloading the latest drivers from lexmark.com
Posted on Jun 09, 2008
You guys were right it was the fire wall.. disengage firewall and scan straight to it
Posted on Dec 24, 2009
  • 24 Answers
Fiend your solution direct from Lexmark. Here is your solution
Lexmark Scanner -
http://www.lexmark.com/printer/prob676ijt65/solution
839
Posted on Mar 02, 2009
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 29 Answers
SOURCE: Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
854
Anonymous
  • 254 Answers
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Posted on Mar 07, 2009
Lexmark 5400 series won't scan. Get message "cannot retrieve application list. I use a Mac
The first thing I would do is remove the program from your computer, then download the latest drivers from lexmark: visit
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X5470&segment=SUPPORT&userlocale=EN_US&frompage=null#1
choose your version of OS ( OS 10 X, 10.3, etc) and download the file.
Before you install the software in your computer, I would disconnect the printer's USB cable, and wait for the installation program to prompt you to connect it.
I believe that will take care of your problem.
Aug 03, 2011 | Lexmark X5470 All-In-One InkJet Printer
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Lexmark 5400 series
hmmm..what are you using for the scanner function?
http://tinyurl.com/6qcpgy
Aug 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Scanner not working......
try uninstall it then install again
Feb 27, 2008 | Computers & Internet
Lexmark X5470 scanner problem
i had the same problem but if you open the Lexmark All-In-One center (can be found in start --> all programs --> lexmark 5400 series --> all-in-one center) and select scan (it will work)
if you dont have the program installed find your installation disk and when u re-install it, it should come up again
SH33P
Feb 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
119,645 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
