My Hamilton Beach Water Cooler Model 87330 won't stop cooling my water. This just started happening. The water cooling device normally shuts off once the water has cooled, but now it just keeps cooling.
my cooler won't stop cooling.my cooling light won't shut off. what is the problem?my cooler won't stop cooling.my cooling light won't shut off. what is the problem?
AnonymousJul 09, 2008
Started after having it for 6 monthsStarted after having it for 6 months
AnonymousJul 26, 2008
it usuall kicks off once it cools the water. If it does not will it take up a lot of electricity? is there any suggestion of what to do?
Same thing with my water cooler 87330 cooling light won't shut off the fans keep running. Problem started week of August 11th.Same thing with my water cooler 87330 cooling light won't shut off the fans keep running. Problem started week of August 11th.
AnonymousAug 27, 2008
Our water cooler started with the cooling component NOT shutting off.....then the cold water stopped coming out. It now drizzles out....Hamilton Beach has not been helpful. We have unplugged the unit for 24 hrs., sanitized the unit and have removed the bottle of water and let it "dry out" all to no avail.Our water cooler started with the cooling component NOT shutting off.....then the cold water stopped coming out. It now drizzles out....Hamilton Beach has not been helpful. We have unplugged the unit for 24 hrs., sanitized the unit and have removed the bottle of water and let it "dry out" all to no avail.
My water Hamilton Beach water cooler is doing the same thing. It was working fine for the first few months that I've had it but then the cooler kept running and never shuts off. After a few days the water started to slow down then eventually no water.My water Hamilton Beach water cooler is doing the same thing. It was working fine for the first few months that I've had it but then the cooler kept running and never shuts off. After a few days the water started to slow down then eventually no water.
I have the same problem. These units use a pair if thermoelectric coolers with heat sinks to chill the water. There isn't a replaceable thermostat as the coolers are controlled by a chip. I'm tossing mine and buying a Honeywell.
AnonymousSep 27, 2008
Fans run all the time and blue cooling light will not turn off, just started about 2 weeks ago. I took off the back and noticed the fins were very dirty (had this about 1 year) so I ahve cleaned out with compressed air thinking that air may not be circulating freely and cooling the water. I will let you know if this had any effect.Fans run all the time and blue cooling light will not turn off, just started about 2 weeks ago. I took off the back and noticed the fins were very dirty (had this about 1 year) so I ahve cleaned out with compressed air thinking that air may not be circulating freely and cooling the water. I will let you know if this had any effect.
I have the same problem and I think from evrythign I have read it is a issue with the brand! I have only had mine for about two months and it will not shut off. The cooler keeps running. I have the same problem and I think from evrythign I have read it is a issue with the brand! I have only had mine for about two months and it will not shut off. The cooler keeps running.
we have the same problem and the store where we bought it will not take this back. we have had the cooler for about six months and we would like this replaced or fixed so this does not happen anymore.we have the same problem and the store where we bought it will not take this back. we have had the cooler for about six months and we would like this replaced or fixed so this does not happen anymore.
The two round "devices" on the tank are the operational thermostat, and the "safety" overtemp thermostat. It is usually the "operational" thermostat that fails, since it has to cycle a lot and arc internally. It is usually about 120-140 degrees F., and the safety thermostat significantly higher.
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Glen, We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to. Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330). I believe the problem is in the circuit control board, but with out further testing i can't be sure .
fans don't shut off
my water cooling won't shut off. Stays on all of the time
hliuy
I have had mine for 2 years and not it has started this problem where it won't shut off...has anybody found a solution?
Thx,
Dave
