Question about Frigidaire ATF6000ES Front Load Washer
All of a sudden, there is no light on the button. I have check the electric outlet, it is OK. I pushed every button, but it doesn't work. Is there a fuse on my washer? Or anyother problem?
  • patrickchoe1 Jul 27, 2010
    Fuse problem is just a my guess.
    Except fuse, what do you think my washer has a problem?
  • 15,935 Answers
There should be a dedicated circuit breaker in your main panel.
Check that first.
Then verify power at the outlet with a multimeter.
If there is power at the outlet - unfortunately, there is internal damage to the main board (typically from a power surge) and further testing is required.
Thanks!
Posted on Jul 27, 2010
  • 11,896 Answers
There is a fuse usually located in the back of the machine.
Testing a dryer's thermal fuse is much like testing its thermostats. Follow these steps to replace your dryer's thermal fuse.
The wires leading to the thermal fuse are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermal fuse should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature.
If the test you conduct with your thermostat does not produce these results, then you should replace the component.
  • Nate Stansfield
    Nate Stansfield Jul 27, 2010
    A fuse or the plugin or wiring and that's about it.
6ya staff
SOURCE:
Our microwave, tv and outlets do not work. Although our stereo does work and all lights do work.
Could be you have a faulty microcircuit breaker on the dead circuit though a consumer unit that contains fuses wouldn't usually have any microcircuit breakers.
I have known wired fuses to seem ok but have a near-invisible break in the wire. The only way to discover this is to remove the fuse and give the wire a gentle tug with snipe-nosed pliers or forceps.
Nov 17, 2015 | Office Equipment & Supplies
Frigidaire microwave
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
Cannon MG5320 PLUGGED INTO HOT OUTLET WON'T TURN ON?
Try the following:
1) Be sure the electrical plug is pushed in completely into the back of the printer.
2) Press the ON button and HOLD IT DOWN until you see the blue LED light on the front middle of the upper lid.
3) If there is no blue LED, there is no electrical getting to the printer.
4) Unplug printer and after a few minutes, replug it into another outlet that you know is working (use an outlet that already has something plugged in so you know it is working, such as a radio)
5) Press the ON button and see if the the blue LED comes on, if yes, it is your outlet. If not, it is possibly a bad electrical cord you are using something inside the printer is broken.
6) You asked about opening the second cover, I assume you mean the part were the ink cartridges go, once the top cover is opened, there is a small "release lever" on the right hand side corner, near the front that you can push back and lift the second cover.
7) Go to the CANON WEB SITE link listed below and select MANUAL for PC or MAC and check it for possible informtion to assist you in using your printer.
www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mg_series/pixma_mg5320#BrochuresAndManuals
Jul 11, 2014 | Canon PIXMA MG5320 All-in-One Printer
Dishwasher not working, no lights on control panel
If your good with electricity get a meter and with the unit unplugged check the resistance across the thermal switch... it should be 0.0 ohms(omega symbol) if a thermal switch is blown it will be open. and read unlimited ohms... I doubt if it is the thermal switch. Check first if you have voltage to the control board you should have lights on it. If no light then probably The door interlock switch has failed,, that is the first thing that I would suspect as I had that happen on one of my units... figure out how to bypass it or operate it.
Jan 18, 2014 | KitchenAid Dishwashers
Quad wont start
check starter solenoid
should have power at the little yellow ( guessing color ) when the button is pushed
should have ground at the black wire ( if applicable )
yes, solenoid is bad
no, backtrack to the push button
does it have a key switch by chance ???
Dec 31, 2013 | Toys
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Power does not turn on when i push the power button
first make sure there is power to the outlet if it is agfi outlet push the reset button if it clicks its working but inany case plug something in to the same prongs that you know works(eg; lamp,radio,etc to make sure it is working. If it doesn't work go to the circuit breaker and look for a breaker that is not in the on position and turn it off the turn it on to reset it. If the outlet works,check the power cord for cuts fraying or any signs of damage and replace it if it is damaged. if the cord looks fine, check tho door switch(usually a pressure switch that must be fully depressed for the machine to start working. also is ther a power light on the unit? is it a top load or front load? what brand and model # is it?
Jan 09, 2012 | GE WCVH6260FWW
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Frigidaire ATF6000ES Front Load Washer Logo
83 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
