Kidde Nighthawk Combo Gas/co Detector Logo
A
Anonymous Posted on Jul 22, 2010
My Kidde Nighthawk Carbon Monoxide detector was beeping shrilly and read gas. When pressed the reset button it read 221. Problem was it was sitting facedown in a box (i'd just taken it from my old apartment to my new one). Is this an error a sign of low battery or should I be worried?
We have a Kidde Nighthawk Carbon Monoxide detector. Last week our breaker tripped and ever since then our detector has been beeping once every 15-20 seconds. The detector has a code 97 displayed. We can...
Haha, same thing just happened to me and really scared me. Thats not a '97' that is an upside down 'Lb' for low battery. According to the manual: "A 9V battery is needed. If battery is low or missing while the unit is plugged into a 120V outlet, an "Lb" message will display which will blink alternately with a the CO reading every second and the sounder will chirp every 15 seconds."
1helpful
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
2helpful
I have a nighthawk carbon monoxide alarm which is showing nan error code. Please can you tell me what to do to rectify it? Thank you.
You can unplug the unit if it's an AC detector, change the battery for a new one and reset the Carbon Monoxide Detector. If that doen't work, you can have it checked by your local fire department. If the unit is more than 5 years old, it absolutely needs to be replaced.
Whenever in doubt about the efficiency of a carbon monoxide detector, a replacement is recommended. Yes, protection has a price, but a life cannot be replaced.
Read more industry information, buy your next Carbon Monoxide Detector here.
17helpful
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
21helpful
2answers
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
16helpful
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
3answers
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Top Kidde Home Security Experts
 Mikey
Mikey
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
