I have bought a new aerodyne 07301132. However, i am not able to set the time zones, day, and time. Also, i am not able to set the alarm for the same. Need instruction manual or some one who can help with this
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Thanks!! I already tried that option out but it does not clearly states what to do for Aerodyne watch..However, I tried the options and they doesnt seem to be working..:(
