Was running then engine slowed down, and stopped. Started a couple times, and the would not start? Checked, and cleaned plug, Would not help. Took plug out put a small amount og gas in pluy hole replaced, and would start, stopped right away? The prime bulb you push to prime does not seem to get fuel. Pulled gas tank, and lines out to check, all seem to be clear, yet cannot get fuel to get through carb, to engine to run???
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Check primer bulb on carb. Could Have split or crack in it.
Sounds like the fuel lines are crossed. Either the in and out lines on the primer are crossed or the primer line on the carbureator is crossed with the normal feed line. Good luck
Michael E.
