I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
Hi , Could be oil from the drum bearings if its noisy during spin. Could also be residue from the drain/ Sink disconnect and check drain hose is it very dirty...........
Make sure you are diluting the fabric softener before putting it into the dispenser drawer. Full strength softener will sometimes stain clothing that's why in the owners manual they always tell you to dilute it first before adding ,plus it last a lot longer and is just as affective... Hope tis helps
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
this may due to softener,put spray and wash on stains and let it set all day,stop using softener use HE detergent and oxy clean powder wih soap in dispencer,also you may want to sanitize washer before you wash shirt also use the stain setting and extra rinse.thanks
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
At the end of the cycle, the wash plate nutates for approximately 30 seconds to fluff the clothing after the final spin. The action of fluffing causes the outer wash plate seal to rub against the stainless steel basket while they are both relatively dry. This condition causes the gray discoloration. RESOLUTION: An updated machine control, part number 8542693, is now available. The updated control reduces the fluff time from 30 seconds to 8 seconds, allowing the clothing to be fluffed, without causing discoloration. Gray marks or smudges can be washed out of clothing after wiping down the basket. The consumer should use the recommended amount of HE detergent and the hottest water safe for the fabric or hand wash the garment under running water. In either case, the fabric must be cleaned prior to running through the dryer
Problem Solved !!!
Ok, I had to stop and tell everyone about my latest experience.
When we moved here we bought the nice Whirlpool front load washer and dryer set.
I Love them....still don't understand how my clothes get clean with so little water, but love them. ..................That is until lately.
I was really upset about a total of 4 white blouses that looked to have some kind of light splattered stains on them after washing. I would try to wash them again with a stain remover sprayed or scrubbed on the spots, but they wouldn't come clean. I gave up and considered the blouses ruined. I told William what was happening and he called the repair man out because he thought it might be some kind of part in the machine that was leaking oil onto the clothes when they were washing.
The guy came out and told William that there wasn't anything that could go into the washer tub and get onto the clothes. He then looked around in the washer and at the little detergent dispenser drawer. He suggested that we use 1 cup of Clorox and 1/4 cup of dish washer detergent (cascade with dawn degreaser crystals) on a hot to medium water temperature and turn it on a complete wash cycle to make sure that we didn't have mold and mildew setting up in our machine.
After he left, I proceeded to do what he told us. I though.....the blouses are probably ruined anyway. I had tried to get out all the spots to no avail, so what the heck......I threw them into the mix too!
Would you believe they came out clean, very bright white (instead of yellowed or dingy from continued wear) and the washer smells as sweet as it did when it was new. Why didn't they tell me about this when I bought it ???????????
I plan on putting the detergent mix in the washer every couple of months and throwing in all the whites that I can find to take advantage of the cleaning effect on the whites. (I thought that maybe some of you had gotten stains on white clothes that you would like to get out too)
