Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Hi
First
check if the drain hose is not clogged and try to clean it as it can be that
the hose is clogged and the water is not draining properly. After that check if
the drain pump filter is fine and not clogged, try to clean that as well. After
this check the metal filter, impeller cover and the air gap unit. After checking this you can
reset the error as follows: turn the rotary selector switch to "Stop/End" or
press the "Start/Stop" switch for approx. 5 secs. Then switch the
appliance off and then back on again. Hope
this helps...please post back for further assistance.
Daniel
