I have same problem. Washer vibrated badly during spin cycle and door subsequently came off because back panel..Mfr. # 00432074 cracked near hinge. Looks to me like hinge must first be inserted before panel replaced. I do not have proper tool either.
Motor brushes, worse case scenario motor complete. Run the following motor test. 1. Put main dial to off 2. Press and hold start button whilst turning dial one click to left (easycare 30). 3. When display show 8.88 or two of the progress light come on, release the start button 4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over) 5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin. 7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault. As suggested brushes or complete motor. Hope this helps
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
The door is probably locked, because the water is still draining. If this is not the answer, the the suction between the dor and the opening is too strong and you must get it weakened by a professional. There is one more solution, and that is to unplug the machine, reset it, and then try opening the door.
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
