We want to change the way the door opens,from left to right,to right to left.how do i achieve this?? i se there are screws on the top of the fridge,but the post between the freezer door and the fridge door,which allowes the doors to swing,how do you change that?? thanks for your help..
Some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
on the top right hand side of the refrigerator you should see little screw cover caps,, also on the door and on the bottom of the door. remove these caps -- now remove the screws that hold the hinges for the door and just switch everything over to the other side. everything is a mirror image of the other side --- where there is a screw that holds the hinge on one side -- there will be a screw hole on the other side that is covered by a finish cap,,, same thing with the hinge pin hole. tighten everything up and use the finish caps to plug up the now exposed holes and there you go -- right hand opening door.
if you have any troubles -- just write me back here and I will do my best to walk you through it.
REVERSING DOOR SWING
Your
dryer is designed so the door swing may be reversed at any time without
additional parts. Conversion is accomplished by transferring hinges to
the opposite side of the cabinet.
To change the direction of the door opening:
1.
Open the dryer door. Remove the four hinge hole plugs from the left
side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
Unplug the dryer. Remove the lint filter. Remove the 2 screws at the lint filter opening. Use a putty knife between the top lid and the front panel to release the clips. They are about 2 inches in from right and left sides where the top meets the front panel. Lift the lid towards the rear of the dryer. Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside. Place the new belt over the drum,ribbed side towards the drum. Look under the drum for the belt tensioner. It is S shaped with a wheel on it. Place the base of the tensioner in the slots below the motor pulley. Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel. Place this side of the belt over the motor pulley with the ribbed side touching the pulley. Replace the front panel. Hook up the door switch wires. Replace the panel screws. Reattach the top lid and lint filter screws. Replace the lint filter. Plug in the dryer.
The instrument panel and steering column must be removed to remove the heater assembly. Two people are required to remove the assembly from the vehicle.
Disconnect negative battery cable. Disconnect positive battery cable and wait one minute for air bag diagnostic monitor to deplete the backup power supply. Loosen main wiring connector bolt in the engine compartment at the left side of dash panel and separate connectors. Remove radio antenna stanchion and disconnect cable from base of the radio antenna stanchion. Remove both the right hand and left hand windshield side garnish mouldings. Do not remove safety belt retaining bolts in next step.
Remove the screws retaining both the right and left front door scuff plates and remove the front door opening weather-strips from body flanges. Remove the right and left cowl side trim panels. Remove the steering column cover by removing the three screws along the bottom and pull on the cover to unsnap the three clips across the top of the instrument panel steering column cover. Remove the ignition switch lock cylinder. Remove the four screws retaining the steering column shrouds together and remove the steering column shrouds. Install the ignition switch lock cylinder to prevent the steering wheel from turning. Disconnect the wiring connectors at the turn signal and windshield wiper switch. Remove the one screw and A/C evaporator register duct from under the steering column tube. Disconnect the wiring connectors at the bottom of the steering column tube. Remove the pinch bolt attaching the steering column tube to the steering column lower yoke and slightly spread the joint with a screwdriver. While supporting the steering column tube, remove the four steering column tube retaining nuts. Remove the interlock cable retaining screws and shift actuator cable fitting. Carefully remove the steering column tube from the vehicle. Loosen the main wiring connector bolt at the left side of the steering column opening and separate the connectors. Disconnect the stoplight switch wiring connector. On the manual transmission, disconnect the clutch pedal position switch wiring connector. Pull back the floor carpet as required on the left and right sides of the vehicle and disconnect the window regulator safety relay switch wiring, and the powertrain control module from the main wiring. Open the glove compartment to the stop, unsnap the hydraulic lift from the right side. Remove the three screws at the bottom retaining the glove compartment door hinge and glove compartment to the instrument panel. Remove the glove compartment. Reach through the glove compartment opening and disconnect the wiring and vacuum hoses/connector from the heater-A/C evaporator housing. Disconnect the wiring connector from the speed control amplifier and bracket assembly. Remove floor console panel: Open the console panel glove compartment door to access screws to console finish panel. Remove the two screws, and lift the rear of the console finish panel to unsnap retainers. Reach under the console finish panel and disconnect wires to fog lamp and ride control switches (if equipped) and cigar lighter socket and retainer. Lift the rear of the console finish panel and slide rearward to release the two front locating tabs, remove console finish panel. With the console panel door open, remove the console glove compartment mat. Remove the center screw from the console (rear of shifter) bin, then lift the bin from the console panel. Disconnect the luggage compartment door release switch and fuel filler door lock switch (if equipped). Remove the two screws from the bottom of the console panel bin to floor pan. Remove the two cups and screws. Remove the floor console panel. Remove the two screws retaining the front of the floor console panel to the instrument panel. Disconnect the remaining wires (main jumper wire) and main wiring, then lift the console panel from the vehicle.Protect the instrument panel surface during next step. Using a putty knife or similar tool, insert under the left or right corner of the instrument panel upper finish panel and pry up on the instrument panel upper finish panel to release one snap clip. Unsnap the remaining four clips pulling up by hand, working toward the opposite side of the vehicle. Remove the two nuts retaining the left side of the instrument panel to the cowl side. Remove the two nuts and one bolt retaining the instrument panel to the console bracket. Remove the nut attaching the right side of the instrument panel to cowl side. The following steps require two people
