Hello, Get down to basics, plug a hair dryer into your wall socket where you had the shredder plugged in and make sure the power is OK. Then if the power is OK, get hold of a multimeter and measure the two points on the plug, make sure the trip switch is reset on the shredder. You must measure the resistance(ohms), should read a very low resistance. Get somebody to help you, if the shredder did work before and not damaged physically, then there should be no reason it won't work! Regards ED
Depending on how old it is just get a new one they are not worth trying to get mended
I have a McCullough electric chipper/shredder. It has not been run for a couple of years but will not start. The blade goes around but nothing happens when it is plugged in and turned on.
