Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
