Maytag PYE2300AY Electric Dryer Logo
Posted on Jul 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rust colored mark or short line on tee shirts
I am seeing a "rust colored" mark or short line on most light colored tee shirts that I dry. what could be causing this?
KB HomeMaker
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 14, 2013
KB HomeMaker
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
20445
Points
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
  • Sharon Kirkpatrick
    Sharon Kirkpatrick Jul 12, 2021
    Thanks for the helpful answer!
    Any idea how to get the stains out?
Anonymous
Level 2:
New Friend:
  • Expert 112 Answers
  • Posted on Jul 20, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
112
Questions
0
Helped
33209
Points
255
Most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
1helpful
Makes a noise like there is loose change in the dryer. Grey marks are coming off onto the clothes. checked. there is nothing inside the dryer or in the pockets of the clothes. Still happens- even with...
This sounds like a faulty drum bearing. The grey marks you are seeing are grease from the bearing. The loose change sound is from the remnants of the bearing rotating as the drum turns.
Mar 09, 2010 • Dryers
1helpful
For some reason, my washer is now starting to leave rust color stains on my clothes. Not on all clothes but only on the corner areas of clothes like the tips of the collars on mens shirts or the small...
If you wash your clothes with warm or hot water, try using ONLY cold to see if the problem goes away. Sometimes older water heaters start to produce rusty-colored water as they age.
1helpful
Clothing coming out stained with rust colored marks-purchased dryer in 2001
The felt needs to be replaced around the drum. When it wears out, this will cause these marks. The felt is the seal that allows the drum to rotate around the door.
Apr 16, 2009 • Dryers
Red t-shirt has run all over the wash. now have pink socks, pink backgrounds etc
did you dry any of this load in the dryer? If you did, the color is set you wont get it out.
If not rewash everything, Except the red t shirt! in the Hottest water the clothing can take. If its whites use a little bleach. you could also use a color safe bleach on colored items. You may want to divide up the load into similar items. Experiment what have you got to loose.
One time we washer a gray sweatshirt with a red sweatshirt, why the gray turned Pink! I dont know we line dried it and washed again, The pink came out.
Good luck
2helpful
5answers
Dryer is leaving brown streaks on cotton clothes
Dec 30, 2007 • Dryers
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
