Insert the DVD into the tray and does not read
Tries it with other dvd discs,same problems.The dvd player,properly have to have it laser eye clean.Tries websites like Amazon.com,Ebay.com to buy a dvd disc cleaning kit,cleanning the eye this way,might work,might not,but u don't have to have take the dvd player aparts,psysically cleanning the laser eye with some Q tips with rubbing alchahol.
Its not the laser. It seems the problem is the little plastic sprocket that is mounted on the motor that moves the laser back and forth. It has a tendency to crack, which causes the gears not to mesh. Its an easy fix. just remove that gear and take a small drill bit and make the hole larger (but not too much) to minimize pressure on the gear. Reassemble and it should work like new.
IMPORTANT ! ! !
If you keep getting the "Bad Disc" error, just do as follows"
1) Push "Set Up" on remote
2) Use arrow to get to "System" and push "Enter"
3) Use arrow to get to "Reset" and push "Enter"
SOURCE: Just Loading - Bad Disc
Normally I would say clean the laser lens, but I actually had the exact same model with the exact same problem, and that didn't work. I was able to get mine to work sometimes by turning it off and on and unplugging it, but even after opening it up, re-lubricating the gears, and replacing a few capacitors near the reader, I never did find a permanent solution.
I guess this isn't what you wanna hear, but I think its an untraceable problem with the motherboard.
