Moen 2 Handle Lavatory Without Drain Assembly - 8966 - N/A Logo
Posted on Jul 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LOW PRESSURE HOT WATER SIDE
ALL OF A SUDDEN I HAVE LOW PRESSURE OUT OF THE HOT WATER SIDE OF THE FAUCET. THE COLD WORKS GREAT AND ALL OF THE OTHER FAUCETS IN THE HOUSE WORK FINE.
Anonymous
Level 3:
  • Master 760 Answers
  • Posted on Jul 19, 2010
Anonymous
Master
Level 3:
Answers
760
Questions
0
Helped
490680
Points
2276
Disassemble the hot water valve. Look for calcium or any other materials, and clean. If you see white plastic particles, then it's probably from your water heater down tube
American Standard Edgewater Single handle pull out faucet. Hot water pressure trickles.
mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
Hot water has great flow. Cold barely drizzles out. NOT a water pressure problem. What/How to check on faucet?
Faucet may have scale desposits on cold water side that would restrict flow. The shut-off valve for the cold may not be opened fully. If a saddle valve for refrigerator ice water was installed, it may block off flow for cold water. Check these items first, then ask more questions.
May 11, 2015 • Plumbing
Barclay 4073-PL Diverter Bathcock Tub: Thoughts on why the water pressure is low on the hot spigot but not on the cold, and not on any other faucet in the house?
Debris can get into the shower body/cartridge. Pull out the cartridge and flush the shower body and clean out the cartridge. Sometimes you need to replace the cartridge.
Nov 07, 2014 • Plumbing
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
The water is luke warm and the pressure is lower than ususal.
We probably need more information to give a good answer.
You report 2 different problems occurring at once: Low pressure and Low temperature.
If this is tankless water heater, then Low pressure and Low temperature might be related, and you probably need a service technician to diagnose and repair cause.
If this is tank-type water heater, look at label on side of tank for type and brand of heater.
Is it gas or electric water heater? Troubleshooting is totally different for each.
Is water pressure pressure low on just the hot side faucet, or is cold side faucet affected too?
Are all hot faucets affected by low pressure?
If you have a dual handle faucet, open hot side only and check if hot water that comes out is hot as normal.
This will say if problem is pressure or temperature.
Tank-type water heater usually won't have both these problems occur at one time, but water heaters work in funny ways sometimes.
Add a comment to this post, or re-post your question with details so the experts can give a solid answer and not guess.
Also you can post water heater questions on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
1helpful
2answers
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
1helpful
Kitchen Faucet 6310 020 White - HOT WATER SIDE NOT WORKING
The faucet cartridge is more then likely blocked and the faucet will have to be disassembled in order to unblock it.
While it is disassembled you should slowly turn on the water lines to make sure the water ways in the faucet are clear. And thoroughly check the cartridge for damage. Replace if necessary.
Replacement Cartridges can be purchased at most plumbing supply houses or Big Box Stores such as Lowes or the like.
4helpful
2answers
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
