Does anyone know how to remove the telescopic handlebar from the Quinny Buzz - I have a secondhand replacement, just need to get the original off to swap it over
Pull the handle up almost all the way, the plastic pieces that hold the handle in place come out by pusining in the little black plastic dot but the handle has to be in the correct position. Move the handle up and down till you can easily push in the dot. The handle should then come off easily enough
I have the same problem with my Quinny Buzz; where did you find the replacement? I need one...
_____ QUINNYSALES_____ PROVIDE A SAME DAY HANDLE BAR REPAIR SERVICE INCLUDING NEW GRIPS FOR £35.00 CONTACT 07886531199
THE HANDLEBAR NEEDS TO BE 10MM LOWER THAN THE HIGHEST SETTING THAT WILL ALLOW YOU TO REMOVE THE PLASTIC CAPPING THAT STOPS THE HANDLE BAR COMING OUT
QUINNYSALES REPAIR THE HANDLES 078865311999
________ Quinnysales______ raise the handle bar to its top setting then lower 15mm ,that will allow you to push the round plastic tabs in that hold the collers in place ,then simply withdraw the handle,if you need new cables then call me on 07886531199 as i offer a unique repair service !!!!!
