1995 silverado 4x4 5.7l 350 block wont start fuel injectors dont open when trying to start gas doesnt go threw.
SOURCE: fuel injectors location for a 1995 chevy camaro
that year uses a throttle body injector, which is located underneath the air cleaner. take the cover off and then take the housing for the air filter off. its right there
SOURCE: gas not spraying at throttle body
replace the injector - before you do that test voltage going to the injector- is should pulse on and off to open and close it
SOURCE: 1996 suburban wont start.
first you have to measure the fuel pressure with a guage, pre start and cranking, it should stay approx thesame, next check for injector signal to the injectors , use a noid light,
SOURCE: 6.5 turbo diesel wont start
check the high pressure oil switch next to the glow plug controller. if the switch is bad you will not get any fuel to your injector pump. unplug the molex and jump it out. this will bypass the switch. if it runs, just buy another high pressure oil switch. good luck!
