Hi all, I recently purchased Selecttech 1090 dumbbells. I was using both dumbbells at 40 pounds each then as i was sitting up to put them away, one of the plats fell of, sending the weight select spinner to 35 pounds on one side. I picked up the plate, put it in its correct position in the rack and i place the handle in and it does not sit properly and i am unable to change weight.
Weight plate that fell off does not lift up with handle.
Thankyou!
Thank you! I found the reset button and now it works again.
I recommend that you become stronger so that you can better handle yourself at the gym and not have to worry about stuff like that. Try SARMs. Why do people wear gloves for weight lifting http://101sarms.com/
what a garbage answer
SOURCE: Selecttech 1090 Dumbbells: the end caps that adjust the weight are stfrozen, ...
Just call Bowflex. If you don't want to call here's the solution. There is a reset button on the bottom of the handle. Take the handle out, place on the floor side ways, depress the square button and turn to 5 lbs. Whatever weights that were on handle will fall out. Place the weights back into the holder. Make sure they are positioned correctly then put the handle back. Then test by dialing up different weight settings and lifting the ******** out of the holder. You should be back in business. If that doesn't work call Bowflex which you should do anyway.
