Anti-locking brakes system, with hard stop's or wet roads ABS, will not let you lock your brakes (skid), this way you can keep control of your car and come to a safe stop.
ABS is anti-lock braking system. It is a range of four sensors which monitor the braking capability when you apply the brakes. If you are harsh and stamp on the brake pedal there is a risk of the wheels locking up and sliding (screeching from the tires).
The ABS sensors modulate the brake caliper pistons andapply and let go the brakes very quickly. This stops the tires from skidding and you will feel a pulse through the brake pedal as the hydraulic system is forced to release the pedal slightly for a fraction of a second.
As ABS stops your car from skidding it allows you to turn the steering when you are braking hard. This is good news for avoiding accidents. If you lock the wheels on a non ABS car, you continue in the direction of the wheels - unless you release the brakes and reapply quickly (same method as ABS) this is called cadence braking but when involved with a potential accident the last thing on people's minds is to release the brake pedal. Having only owned older cars, cadence braking is one method I've learned, especially from driving in the snow.
I hope this helps you and please vote for me :)
