There is a light "on" on a "lock" symbol under one of the Heat/Dry incons...the machine will not re-set & will not turn on....any ideas?....I cannof find my original manual...please help.....I'm sure is some type of locking mechanism but I do not know how to reset- it....please help
SOURCE: dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
SOURCE: the lock symbol located at the dry button is lit
check your door lock make sure it has correct voltage and has not been closed indicating that it is locked.other than that replace the control board
SOURCE: have the Frigidaire FDB520RHS2 model with a locked feature?
unit is in lock position hold three seconds
Hello &
Welcome to FixYa
The lock
light that comes on indicates that the control is locked and you reset the
control to solve this problem. To unlock/reset the control press and hold the
NO HEAT DRY/AIR DRY/RINSE ONLY button for 15seconds. Please get back to me if
you have any other questions.
Kevin
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
