The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
I have a model LN32A330 which is probably has connections similar to yours. I'm not home right now to check whether it has a digital output, but I know for sure it has an analog audio output available. You can run that output to an available auxiliary or a/v source input on the receiver and that will work for you. That's how I have mine connected. If the set has a digital output and the receiver offers digital inputs, that's another connection possibility. The digital output on some brands of TV only works in conjunction with the tuner, and may not always have output. The analog method is guaranteed to work.
If this solution has helped get you on the way, please take a moment to give it a fixya rating. Thanks for asking here!
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
If you have a VCR it is easy. Just plug RCA cables into audio out right and audio out left (on VCR) and other ends into VCR audio in right and left at rear of your receiver. If there are two sets of video audio inputs, push button on front of receiver to agree with where you plugged cables in. (ie. Video 1 and video 2)
it may be muting due to a fluctuation signal. Do you have an appropriate aerial connected to the FM tuner?. a length of speaker wire pulled apart into a t shap for about 1m will do. Get a splitter and use you television antenne coscket to provide better signal for your tuner
