Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing.
Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up.
Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray.
While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
how do i put together - 0dd7df2.jpg />
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attachow do i put together - 1c98cfa.jpgspan>
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Thehow do i put together - 2c42a04.jpg Headlight Hood
The Tank is removable and should be filled or emptied, at your sink.
NOTE: Tank is removed and re-attached in the same way as the Mini Em-Tor
Unscrew the large cup from the top of the tank and turn the Suds Control Valve fully to the left (counter-clockwise) to OFF.
Holding the tank level, fill tank to the full line with warm water (not hot).
Pour three capfuls of Kirby Carpet Shampoo into the tank. Do not use more, as over-foaming will result.
NOTE: One tankful of solution will clean about a 9x12 foot carpet (3x3.5m). Larger carpets will require refilling the tank.
Replace the large cup into the opening on top of the tank.
Taking care to avoid spilling liquid on the Kirby or the floor, place the opening in the bottom front of the tank over the Air Exhaust Pan on the Kirby. Angle the tank outward from the Kirby until the arrows line up. Next slide the tank down over the locking pins on the Air Exhaust Port.
Rotate the tank toward the Kirby to lock it in place.
Push the round elbow into the hole in the tray until it snaps into place. Firmly insert the other end over fitting at the bottom front of the tank.
And there you have it.
Last picture
