Am trying to determine the proper way to replace the front wheels on my tractor. The diagram for the steering assembly on Page 42 of the manual suggests I should begin by sliding on the two larger washers, then the tire, then a smaller washer, the retaining clip and the hub cap. ... On Page 28, a drawing in the maintenance section shows the two larger washers on the outside of the tire. ... The two drawings contradict each other. Can anyone tell me which is correct? Many thanks
SOURCE: Can't get front wheel back on lawn tractor Craftsman 52-inch
Make sure you are putting the wheel on the right way. The rim may be off-set. The longer part of the hub should be on the inside.
are you putting it on backwards or opposite the way it came off maybe
