Question about Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo
Lifetime Portable Basketball System- The pole are stuck.
Assembling court I accidently reversed the top pole (ALH). I seated the bottom pole (ALE) and middle (ALF) Now they are stuck and I can't pull them apart to change the top ple (ALH) to its rightful position.
  • 16 more comments
  • Reed Good Apr 20, 2013
    Worked like a charm! After 3 drops from about waist high, we were able to pull the pole right out. Thanks for the tip!
  • hokies95
    hokies95 Nov 29, 2013
    I was stuck in the same position, in addition I actually 'jammed' the 2 poles together by banging them on the groun 6 times to seat the 2. I added WD40, and dropped from shoulder length on the grass. Popped out after the 10 time. I dropped from a little bit of an angle
  • ally
    ally Dec 25, 2013
    Genius! This tip just saved Christmas at our house! THANK YOU
  • K Boone
    K Boone Dec 25, 2013
    Brilliant! You saved Christmas here, too. Ours didn't work at first, and we didn't have WD-40. So we heated the joint up with a blow dryer and then tried again some more from shoulder height. Finally, they just popped right apart. Thank you!
  • Mitchell Stearns
    Mitchell Stearns Mar 23, 2014
    This solution is like the Energizer Bunny, it keeps working! I have 4" square poles for a Spalding 68454 system. I thought I followed the instructions to the T, and when I went to assemble the mechanism to the pole the holes were on the side instead of the front. I was beside myself wondering how these things were going to come apart. Then I Googled it and here I am. Just a few drops and the top section fell right off. Forty or fifty drops then a nice coating on all four sides with 3-n-one oil and just a few drops more, shabam! Wooo Hooo! Thank you so much for this idea, sure saved me a lot of money having to find replacement poles! THANK YOU, THANK YOU, THANK YOU!!!!
  • John Dixon
    John Dixon Mar 23, 2014
    Fantastic! I'm glad I'm not alone. I have a Spalding 68564 and the dimples slid just slightly off the channels when putting the poles together. Each of the three sections were just slightly off, but when you put the rest of the parts on, slightly off becomes a major issue. I prayed the poles where the sections come together and left the WD40 sit for a few minutes to let it do its work. I then dropped it repeatedly as suggested from chest high. The dimples started aligning after 10-15 drops! I'm sure I could have pulled it apart, but there was no need to do it. Thank you all for posting your results!
  • Terry
    Terry Apr 06, 2014
    just used the wd 40 and waited about 15 mins then dropped in on the grass a few times and it came right apart. Although we are still putting it together for the past three hours. (this is my husband is, i cant go out there when he does things like this. lol
  • Mark
    Mark Apr 25, 2014
    Thanks so much for posting this! I realized that I put the top pole in backwards after I put the bottom two together, then could not get them apart to fix it no matter what I tried. I used your "waist high drop on the side" technique and they came apart after about 50 drops. I'll admit, at first I was skeptical of the technique since they were fitted so tight together, but after about 15 drops I noticed that the pole connection moved about 1/8". That made me believe and continued on about 35 more times and they came apart, yea!!! Thanks again!!!
  • Tony Callaghan
    Tony Callaghan Jan 03, 2015
    I'm now having this same problem. The difference is I haven't realised till i've got to the last step of connecting backboard poles to main pole. I've done this over a couple of weeks so the pole is a little rusted inside, not to mention connected to the base. Not sure if this method will work for me?
  • D Hendry
    D Hendry Jun 11, 2015
    The WD-40 & dropping on driveway (4X) worked for us. Thanks for the postings; saved us time and money.
  • Sharon Pina
    Sharon Pina Jul 13, 2015
    How do I drop it. Mine is wedge tight
  • Greg Pickering
    Greg Pickering Jul 31, 2015
    This worked perfectly.. I dropped the pole twice and presto the poles came apart. I so glad I looked online to see if anyone had the same problem I was having. Thanks for the information.
  • Narelle Lloyd
    Narelle Lloyd Apr 03, 2016
    OMG this totally work. We got the poles stuck and put some WD40 and dropped horizontally from head eight onto the grass about 4 times......and BOOM it worked like a treat. Thank you Thank you Thank you
  • Kelly Rachele
    Kelly Rachele Dec 26, 2016
    Worked perfect for us. Dropped it about 20 times.
  • kerry demarco
    kerry demarco Aug 12, 2017
    Thank-you all, we dropped ours about 6 times and it worked!!! My husband didn't believe it was going to work, but I knew so many of you couldn't be wrong. Thanks!!!!
  • Rita
    Rita Dec 24, 2017
    This worked!!!!! It only took about 5 tries. This saved our Christmas. Definitely drop it on an angle. So happy!!!!!!
  • Dave powell Oct 19, 2018
    Saved the day! Awesome!!
  • Robert Stanley
    Robert Stanley Apr 21, 2019
    Thank you to all who took the time to post the hack for this problem.... saved the day!
    New Friend:
Deddy456 was spot-on with dropping the poles from waist level. Worked for our Spalding that looked hopeless. Thanks!
Posted on Nov 20, 2011
  • 2 more comments
  • candisswynes
    candisswynes Feb 19, 2013
    OMG thanks so much worked after two drops. We hd tried everything from trying to pull it apart with hands and the car, oil, ropes. thanks again for this great advice.
  • delo green
    delo green Nov 12, 2013
    i ended up taking my tubes to a muffler shop, and they got them out because they were in so deep. just paid the guys in the back of the shop $20
  • EricaO Sep 02, 2015
    Thank you, thank you, thank you. I appreciat so much. It works wonders, I am really thankful
  • Natalie Oct 26, 2019
    i was skeptical at first, but it actually worked! Thank you so much, saved me so much money and time.
    New Friend:
We have a spalding 48" basketball hoop and we accidently put the top and bottom poles together, skipping the middle pole. Not good. We tried pulling it apart with 300lb ratchet tie downs and it did nothing. Hammer and wd-40 did nothing. Finally, we tried dropping it from shoulder height onto the grass. Miracle! It took maybe 75 drops and then we just tugged it apart. Made me think of a Chinese finger trap. Whoever thought of this solution is a freaking genius!
Posted on Aug 23, 2012
  • 2 more comments
  • Alexandra Evans Dec 26, 2012
    Thank you Jessica, I wedged the basketball system poles in the wrong way and couldn't get them apart. After hammering, pulling, spraying with wd40, I consulted the internet and saw your comment. Sounded crazy but we tried it. On the third drop the poles separated. Thank you, thank you, thank you. Sharing your experience saved me so much stress and disappointment. Three drops from shoulder height, unbelievable.
  • Mimi
    Mimi Apr 13, 2014
    Really works! wd40 for 15 mins dropped in grass from shoulder length and poles easily came apart. THANK YOU!!!!!!!
  • valou
    valou Jul 28, 2014
    Thanks you so much we thought we'll never manage it ! it works easily after 3 or 4 drops .
  • Aparna Harikumar
    Aparna Harikumar Nov 25, 2016
    It worked. I was about to return it or call someone but just checked the internet and found this.. Thanks a ton. 10th drop did it!!
    New Friend:
The exact same happened to me. Did you ever figure out a solution?
Posted on Jul 10, 2010
  • 8 more comments
  • mfuj Jan 21, 2011
    After trying all sorts of things to separate the two poles from hammering the top pole out of the bottom to pulling apart with two people, I finally called the company, Huffy at 800-558-5234. I explained that the directions were a little confusing and it was difficult to see where the poles should align. The representative was very apologetic and told me it happens quite a bit and that I probably was not going to get them apart. They are sending out new poles to me for free and should be here in a week. If it's not a Huffy product, call the company.
  • sierracc Mar 18, 2011
    My son did the same thing. It appears it's common. I called the Lifetime support number and received a SOLUTION that worked. 1) get a piece of cardboard at least as long as the pole. (this protects your floor
  • nvsliz May 01, 2011
    wheres the rest of the answer pal?
  • nvsliz May 02, 2011
    try screwdrivers or metal rod through the holes on each part then lube the join and then with a partner twist the poles in opposite directions holding the metal rods, like unsrewing something... worked for me, if poles dont have holes in them drill some
  • deddy456 Jul 18, 2011
    take all screws out, and all brackets etc off of the poles. Take cardboard and our carpet, etc as long as the poles, take the poles and put them waist high and drop them flat onto it for as few as 3 times, or as many as 30 and they will separate.
  • bloomieslp May 21, 2012
    I had this exact issue when putting this together for my friends son. We did not line up the top and middle correctly and could not separate them with wd40, pulling, hitting with a mallet, etc.... Placing a piece of cardboard on the garage floor and dropping it from waist height about a hundred times totally did the trick! Thanks!
  • SierraAZ Dec 23, 2012
    I misread the instructions on assembly and figured we were going to have to pay for new poles before I saw this. We sprayed a lifttle WD40 in the hole, dropped it six times in the grass from waist high, and boom, two pieces. I'm stunned this worked that well and easily!
  • Billie Jo Nickols
    Billie Jo Nickols Mar 29, 2014
    I am so glad I found this! I was about to hang my head and go into the store to see if I can order the replacement parts, this saved the money and my pride! (and spared me the whining from my children that the hoop wasn't up.)
  • Sarah Davidson
    Sarah Davidson May 29, 2016
    Amazing solution! Thank you. Saved the day.
  • Thomas Strickland
    Thomas Strickland Dec 25, 2017
    This just saved my Christmas, a totally embarrassed, glad to know I'm not the only one that's done this. Took 10 drops and came right apart.
    New Friend:
OMG amidst frustration, wd 40, screwdrivers and lots of force there was no movement. Googled and tried, 3 X drops from shoulder height, slight angle and done. whoo hoo!!!!!!!!!!
Posted on Apr 14, 2013
  • gabi Apr 15, 2013
    has nayone had a problem with the whole thing being crooked? what a joke for $600 and now they tell us to dismantle it and for another $125 hunter will assemble it after we spend time dismantling it, oh dad and my hubby have now spent over 10 hours trying to get it done. Customer service from hunter laughable, care factor zero from them. What a nice little way to make a buck!
    New Friend:
Thank you Thank you Thank you for these posts! Worked after 6 drops!!
Posted on Jan 12, 2013
    New Friend:
Dropping it on the floor worked! Here are a few tips...do not throw the poles against the grass, drop them...drop horizontally, at a slight angle...make sure your wife is with you so you don't lose your cool.
Posted on Dec 30, 2014
    New Friend:
Miracle! These posts saved us! Tried everything on our stuck poles - no luck. Looked on line - find this and gave it a try! YAy! Success after only two drops!, thank you all!!!!!!!!!!
Posted on Jan 11, 2014
  • Lea Taylor
    Lea Taylor Jan 11, 2014
    New Friend:
Worked ! Dropped it in the grass flat ( even made a mark so I can see the progress) about 70 plus times. Mine was jammed in there good too. Pretty much all the way. Anyway, I was able to pull it apart with my mom while we gently tapped the center with a rubber mallet. Thank you !
Posted on Mar 17, 2015
    New Friend:
It worked great. Thanks for the tip. What really made it come apart was the fact that I did not hold it perfectly horizontal. I tilted it to one side just slightly and dropped it from shoulder height onto the lawn. Got it to work the very first time I tilted it.
Posted on Jan 24, 2013
    New Friend:
AWESOME! You guys are amazing. This really does work!!! WD40 for good luck and 4 drops onto the grass....separated! Thank you! Thank you!
  • Alexandra Evans Jan 16, 2013
    Unbelievable, isn't it. I seriously hammered the poles in the wrong way so tightly and I can't believe how easily they came apart. Glad you had success.
    New Friend:
It worked! A little DW40 and about 10 drops from waist level did the trick!
Posted on Dec 28, 2012
  • Susan Pieck Dec 24, 2013
    This worked a treat!! Thank you so much, dropped it 7-8 times from shoulder height and poles separated! A Christmas miracle!!
    New Friend:
Can anyone find a video
Posted on Jul 14, 2016
    New Friend:
Did anyone have all 3 pole put together? I do, the top one is miss aligned. Tried dropping it from shoulder height about ten times, nothing. Then tried throwing it on grass about 40 times, nothing. Doesn't look promising ??
Posted on Jun 13, 2016
    New Friend:
AMAZING!!!! Worked like a charm after several tries. We stood one end up and dropped at an angle.
Posted on May 30, 2016
    New Friend:
Holy whoa!!! How did you figure that out? Worked perfectly after about 7 drops! This after hours of frustrating attempts
Posted on Jan 03, 2016
    New Friend:
Omg!! My son got goal for Christmas my hubby didn't align dimples correctly. First the instructions are weird. The fellas finally asked me to take a look. So many tools later and WD40 and pulling. I finally said baby let me Google. I found this post!! Thank u and God bless!! This simple trick is amazing! 8 drops at shoulder length directly on uneven ground and poles came shaking apart! We are tickled pink!
Posted on Jan 02, 2016
    New Friend:
I love google! We had the same issue trying to remove the top and middle poles after we misaligned the dimples...it took about 40 tries....it actually only took about 3 tries once we figured out that using the slope/angles of the ground was actually more efficient than trying to angle it ourselves!
Posted on Dec 29, 2015
    New Friend:
OMG, I misaligned the dimple and had it driven tightly together. I had already tried pulling it apart, WD-40, a mallet and holding one pole in a vice and pulling and twisting the other, did not budge. My daughter showed my this thread and I thought she was nuts. 4 drops!!! 4 drops!!! And it came right apart.
Posted on Dec 25, 2015
  • Luc Bessette Jun 13, 2016
    I have three pieces put together, the top piece is aligned wrong. After about ten drops, I tried throwing it about 40 times. It didn't work. Did you have 3 pieces together or just 2? This was my son's bday present, really hope I don't have to buy him a new one!
  • Kelly Brown
    Kelly Brown Jul 04, 2019
    We're the poles round or square?
    New Friend:
Omg!!! I was crying on Christmas morning when I lines up the hole rather than the DIMPLE... this worked like a charm after about 10 drops. Thankyouthankyou!!!
    New Friend:
Wow, just wow. Screwed up both attachments, and this trick worked like a charm. About fifteen drops from over my head, at a slight angle, and they loosened up and came right apart. Thank you to everyone who posted; this was a true life-saver.
Posted on Dec 18, 2015
    New Friend:
Thank you so so much, I really appreciate it worls wonders. I am so thankful
Posted on Sep 02, 2015
    New Friend:
WD-40 just to make sure and dropped about 6 or 7 times from shoulder height. I got a bit frustrated because it was not working at first but I moved to a more uneven location on my lawn and dropped it a couple of times and it worked. This is why I love Googling!
Posted on Jun 24, 2015
    New Friend:
Omg it worked after 10 drops
Posted on May 17, 2015
    New Friend:
After my husband scolded our son for moving the middle piece I was awaken to find a super angry man in the garage. We were pulling at the two parts with 0 luck. I thought surely others have had this issue. Found this thread told my husband to do it. After getting a your crazy look and 12 drops later they came apart and he is back to work.
Posted on Apr 05, 2015
    New Friend:
OMG
THAT ACTUALLY WORKED. TO DROP IT. ONLY TOOK A COUPLE OF TRYS FROM SHOULDER LENGTH. HAD TRYED WD40. SEVERAL PEOPLE PULLING AT THE SAME TIME. SCREWDRIVERS. U NAME IT. BEEN TRYING FOR MONTH. THIS IS SO COOL. IM ECSTATIC OVER THE OUTCOME. HAHA FUNNY. THANK GOD FOR GOOGLE. HEEHE
Posted on Apr 04, 2015
    New Friend:
Yay for whoever came up with just dropping it on the ground to separate them. .. the bottom piece came off easy but it took a few more drops for the top piece to come off
Posted on Jan 12, 2015
    New Friend:
Dropping it in the grass absolutely works. Don't even waste time with WD40, a hammer, screwdriver, etc. It took about 15 drops until it loosened up and I was able to separate by hand. So, save the frustration, busted knuckles, and fbombs and do this. I can't express how happy I am I found this thread. Thank you!!
Posted on Jan 03, 2015
Anonymous
SOURCE:
How do you remove headrest on a 99 chevy astro van
if like my old vans, there is a tab at base, you have to push in while pull up. I seen crack, thought was tearing up, an found the tab by accident. Also.. Some you have to insert a small pointy tool, down the headrest pole, into bottom to hit trigger to release. While pull up same time. Dull end, so do not hurt self,or cut seat. MAy need extra hands. Good luck.
Feb 02, 2017 | Cars & Trucks
Where can I find an instruction manual at for the Northwest Front Porch Tent?
This video is as good as anything although I wouldn't pitch it on a hill! These are written instructions;
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Setting up Northwest Territory Front Porch Tent
Nov 03, 2015 | Sport & Outdoor - Others
We're about to buy a Suzuki XL7 2003 model but can't find the child seat anchor points in the middle row of seats. There are 2 hooks on the back of the middle and the LHS (passenger side) seats - are they...
Check for the seat belts under the seats in that row by pulling up on the little leather or plastic handles found on the side of seat or between the top and bottom of seats. Hope that Helps.
Feb 02, 2014 | Cars & Trucks
How do i adjust the tension on a ActionC100 exercise bike
I just fixed a C100with the same problem today as follows:
Take off the pedals, seat pole, and side panels ( 3 long screws on the top and 4 short screws on the bottom then push out [from the inside] the pedal shaft outlet covers and gently take the covers off by turning the pedal shaft). You'll see the cable to the wheel and secure it to the lower chassis rail by tape or a cable tie, then undo the lock nut on the cable end and extend the screwed sleeve by 10 mm. You'll then see that pulling and releasing the outer cable will loosen and tighten the magnetic brake more smoothly. Good Luck, Andy
Dec 29, 2012 | Exercise & Fitness
Hi my friend has just bought the quinny zapp xtra and when assembling it she has put the seat clips on the sides and now there stuck and she cant get them off any ideas?
hi theres a grey handle at the top of the seat that reclines the seat, push this in hard as far as it will go and theres a little bit next to it,pull that little bit to the (right) and that releses the seat conector part that locks in to the seat,i know wat you mean because mine got stuck,and took me 2hrs to work this owt ? hope this helps caroline
Jul 04, 2011 | Quinny Baby Gear
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
Apr 30, 2011 | Whirlpool Refrigerators
How do you let the back seat down
The third row seats have pull tabs inset into the top of the seat backs. The pull tabs are connected to wires that when pulled will release the catch that holds the seat in place.
The middle seats have the typical lever that on the outside bottom of the seat that you would use to adjust a seat manually in many cars.
Mar 08, 2011 | 2006 Chrysler Pacifica
My seatbelt is stuck on the back middle seat, how do I repair it?
to heavy duty bolts or torx bits that hold the seat belt at each side top and bottom then remove an replace a deffective seat belt is dangerous
Jun 08, 2010 | 2003 Ford Explorer
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo Logo
26,912 people viewed this question
Top Lifetime Sport & Outdoor - Others Experts
Tom Chichester
Vernon Taylor
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
